Results 1 to 2 of 2
Thread: will 07 throttle control fit 05?
    Nov 2009
    newcastle
    Default will 07 throttle control fit 05?
    Hi,
    hope someone can help?
    I have an 05 vectra c estate 1.9cdti 120, with the common fault on the throttle control which gets it full of oil.
    I have cleaned and still a fault with a stutter still pulls up fault everytime from cold but goes away after resetting of code.
    I have put it down to the faulty throttle control. I believe getting the newer "redesigned" throttle control will resolve. Have found a 2nd hand one, but before i buy will it be a direct fit??
    Hope someone can help??
    Richie
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    There is a How2 for the 150's throttle body but I don't think the 120 is any different:
    http://www.vectra-c.com/forum/showth...45#post1338145
    If you put any other throttle body in with out the relevant Op-Com/Vaux-Com software to marry it to the ECU, the problem won't be fixed.
  1. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  2. Throttle control
    By Zeppelin in forum Engine & Drivetrain
    Last Post: 3rd February 2010, 17:44
  3. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
  4. Throttle control
    By Cappersnap in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:04
  5. dodgy throttle control valve
    By micksig in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 16:43
