Thread: Boot light fuse number?
    Woodbridge
    Default Boot light fuse number?
    Going to fit some LED's into the boot today, However I am rather courteous around electrics so I would rather take the fuse out before cutting into wires, so does anyone know what number fuse it is?
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    When I soldered my LED's to to the boot light circuit I ended up blowing one of the fuses, which was fuse Fuse 12 "Battery Control Unit" on the passenger side of the dash (15A fuse)
    Hope that helps Ginge
    Good luck and don't forget the pics
    Woodbridge
    Cheers mate, Did you short circuit it?
    Year : 55
    Mileage : 92,000
    Yep, shorted it twice lol
    The led strips lights I bought of ebay (from china) had no identifying mark to tell which was positive or negative so when swapping wires round it sparked a couple of times and fortunatly blew the fuse (thankfully nothing else lol)
    Woodbridge
    The one's I have, have a copper coloured wire and a silver colour, However, on one light, copper is + and on the other the silver is +.
    Year : 55
    Mileage : 92,000
    Yep same problem as what I had found on mine Ginge so it threw me a little but got there in the end (cheap stuff from China I suppose lol)
    Logic should have told me to check across the battery terminals first to find which was the +'ve and -'ve wire instead of twisting to boot light wiring and shorting the fuses lol (too impatient lol)
    Damo
    Woodbridge
    I have just tested them on the boot light in my car and they are labelled wrong lmao. However, it did not blow the fuse.
    Copper is positive lol.
    What else does fuse 12 control?
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    i put mine in, run the wires and soldered the bits i could that didnt involve the live boot light then i just took the neg off the battery, soldered it up, put the neg back on then tryed them
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Mr Haynes he say:
    Passenger Fusebox - Fuse 12 - 15A - Battery Control Unit.
    Rear Fusebox (REC) - Fuse 12 - 15A - LH Rear Seat Heater.
    Engine Fusebox (UEC) - Fuse 12 - 30A - Windscreen Wiper.
    Take yer pick !
    Woodbridge
    ^^^^^^^Cheers
  1. boot fuse location and number ( if possible)
    By valhalla in forum Electrical & ICE (including SatNav)
    Last Post: 24th December 2012, 14:27
  2. boot fuse number and location
    Last Post: 24th December 2012, 13:05
  3. Fuse for boot light
    By hothatch in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2011, 18:47
  4. Boot light - Where is the fuse?
    By Schui1024 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd March 2010, 01:04
  5. Front courtesy light, fuse number
    By sirnapper in forum Electrical & ICE (including SatNav)
    Last Post: 30th October 2009, 15:41
which fuse controls the trunk light vectra c
