Results 1 to 10 of 14
Thread: temperature guage ?????????
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Default temperature guage ?????????
    hi, over the last couple of days i have noticed that the temperature guage is somewhat intermittent, sometimes it`s not working, turn off the engine and restart and it`s reading normal, i went out for a drive took ages to show anything and then it only went half way to where it should be.
    is this a new thermostat or could it be electrical??
    Sep 2009
    Audley STAFFS
    I would say the stat, mine did a similar thing, new stat,,, sorted.
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Could also be temp sensor. Not sure what electrical range you need for the sensor. Sure someone can help out on that.
    Am not sure if the vec thermostat an housing are attached together or not. If there not take it out. Put in a pan of water on the hob an you should see it open about 85 degrees
    Nov 2007
    LEICESTERSHIRE
    any more thoughts!!!!!!!
    Aug 2010
    Derbyshire
    Quote Originally Posted by VEC-MAN View Post
    What engine do you have?
    Mick
    Nov 2007
    LEICESTERSHIRE
    18vvti
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    I had to change the stat on mine, and I have the same model as you, as mine was all over the dial, now stays on 92 as it should.
    The stat aint cheap for this model, but its an easy job, and a lot cheaper than the stealers! Only issue I had when I changed mine is the wiring bracket on the side of the housing is held on by a realy flimsy bolt, and I sheared mine off when I tightened it back up so be warned........cable ties are a wonderful thing...
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Agreed, classic thermostat failure.
    Nov 2007
    LEICESTERSHIRE
    right thanks guys, thermostat order monday. would i need a new gasket?
    Oct 2007
    south wales
    Its all one unit as far as I remember.
  1. Temperature Guage
    By garetmcc79 in forum Electrical & ICE (including SatNav)
    Last Post: 28th January 2012, 15:28
  2. Temperature guage
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 23:40
  3. Temperature Guage - 05 CDTi 150
    By Gallen in forum Engine & Drivetrain
    Last Post: 15th November 2010, 12:28
  4. Fitting an oil temperature guage
    By Celes in forum Diesel Engine related
    Last Post: 25th November 2009, 18:51
  5. Outside Temperature Guage
    By Del 2.2SRi in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2007, 20:10
