Results 1 to 10 of 11
Thread: 1.8 vvt
    coventry
    Default 1.8 vvt
    Always regretted dobbin in my rattly 150cdti for a KIA CEED (arrrrgh!) a couple of years ago. I'm thinkin of cutting my losses and having another veccy. Can anybody tell me what rpm a 1.8 does at 70mph? AND - if there's much difference in mpg between a 1.8 and a 2.2 direct? AND - does the 2.2 have a 6 speed box? AND - FINALLY -which is more reliable, 1.8 or 2.2?
    coventry
    Default PS
    I also meant to ask - does either of them have a dualmass flywheel?
    Oct 2007
    Ripon
    Can only answer the one Q - mine (1.8) sits at about 3000 rpm at 70,
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    no to the dual mass flywheel either, for a mix of performance and economy id go for the 2.2 meself.
    i went purely for economy so bought the 1.8 ecotec not vvt, wont scare anyone at the traffic lights but does return average of 40 mpg
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by robdd1 View Post
    so does mine, well its 3100 rpm at 70 mph its a 1.8 sxi on a 53 plate,, but the vec I had before was just a L and that had a higher ratio gear box siting at 2650 rpm at 70 mph, my sxi has averaged 38.6 mpg for the over 20,000 miles I have owned it, long M-WAY journeys at 70 mph FULLY LOADED it does 43 mpg, NO DMF
    Regular Member shadyone's Avatar
    Nov 2007
    Northants
    2007 VVT with 17inch wheels 225/45 tyres, 70 MPH is 2800 rpm on the dial, not much in it between the two motors but the 2.2 would off course have the edge as it should with an extra 400cc.
    Regular Member Jezzy's Avatar
    S.E
    1.8 is probably more reliable, the 2.2 can sometimes suffer from failed high pressure fuel pumps and jumping drive chains.
    coventry
    Default 1.8 vvt
    Many thanks for your replies - I'll have to see what's about. So far, the petrols seem a fair bit cheaper than the diesels - I've found a 25K 2.2 SRi estate 08 for £6.5k, and a 35k 150 cdti Sri estate 09 for £9k! I had a 150 cdti a while back - fantastic motor but the engine's poor reputation was always a worry, hence my leaning to a petrol this time. I suppose the 2.2 should be a safer bet than the diesel having no turbo to fall off.
    Anybody know what a 2.2 revs at 70?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the 2.2 direct comes with both a 5 speed and a 6 speed gearbox....
    mine runs at 130 KM/H at 3600 RPM.. and 110 KM/H at about 3100 RPM
    Barrow In Furness, Cumbria
    My 2008 VVT is around 2800 at 70mph.
    How come you want to know that? Is it for fuel economy?
    I remember my old Corsa used to do 3500rpm at 70mph. Used to hate seeing the revs that high. It used to do en extra 500rpm for every 10mph as well, so 80mph would be 4000rpm!
