Thread: Engine Re-Build.
    Regular Member charliedub1's Avatar
    Jun 2011
    Ireland
    Default Engine Re-Build.
    Hi Lads wondering if you could help me out with the following.
    I have a 2004 Vectra 1.6 xe z 16. (Not that common in the u.k I know)
    The car seems to be burning oil. When you rev it up to about 3-4k there is alot of blue smoke. On inspecting the throttle body today I noticed a fair bit of oil in the intake.
    I assuming the worst here and thinking the valve seals and rings are gone.
    Can anyone tell me how big of a job would it be to replace them or should I just startng looking for a new engine.
    Id be grateful for any advice as im up the walls over this.
    Engine : 1.9 CDTi
    Do a compression test and take the readings.
    Then drop a bit of oil down the bores and do the test again.
    If it goes up then the rings are gone.
    Its not a 5 min job to do the rings, Its a complete strip down of the engine.
    Jun 2011
    Ireland
    Quote Originally Posted by lee gsi View Post
    Thanks Lee.
    Can I just ask you this P.C.V valve would that cause the above symtoms?
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    As said mate to do rings is big job an would probably be more cost effective to replace engine
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    And fit a 2.0 turbo lump in it
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by charliedub1 View Post
    Thanks Lee.
    I have heard that the valve can sometimes course oil burning how ever I'm insure how you would test
    Sorry
    Jun 2011
    Ireland
    Thanks lads.....
  1. Self Build Combustion Engine
    By spoons in forum The 'Off Topic' room
    Last Post: 9th June 2012, 09:03
  2. Best way to build up 314/345 calipers
    By R2XPT in forum Suspension, Wheels & Brakes
    Last Post: 30th June 2011, 21:16
  3. Buy Vs build a PC?
    By wardy in forum General Chat
    Last Post: 13th September 2008, 19:38
  4. My boot build
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 07:51
  5. Cheap PC - build yer own!!
    By Ian in forum General Chat
    Last Post: 15th November 2006, 05:20
