Results 1 to 2 of 2
Thread: spanner light
    Regular Member decks's Avatar
    Apr 2008
    nothern ireland
    Vehicle : 2.0t btcc
    Default spanner light
    got the underside of the car washed for mot and now i have the spanner light on, only on start up goes of when started, could the washing have disturbed anything, no codes are stored on my code reader.
    Regular Member BoroDave74's Avatar
    Attleborough
    Did you pressure wash? I often find my external temperature sensor, which is down behind the number plate, can get wet through the lower grill and brings up the spanner light. Clears after a few starts or via decent code reader. Also get that one triggered if you go through a deeper than expected puddle.
    Definitely double check connections under the bonnet. hth
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Problems with Air bag light, ABS, Anti Skid & Spanner light
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2012, 21:23
  3. Should I Have A Spanner Light aswell as an Engine Light on My Signum?
    By StreetDragster in forum Engine & Drivetrain
    Last Post: 18th August 2012, 11:57
  4. EGR Valve, Engine Management Light & Spanner Light
    By guygreen in forum Engine & Drivetrain
    Last Post: 12th December 2010, 20:09
  5. spanner light then engine management light
    By learoy69 in forum Engine & Drivetrain
    Last Post: 12th March 2010, 20:10
http:www.vectra-c.comforumshowthread.php139247-spanner-light
