Results 1 to 3 of 3
Thread: Clock losing time
    Regular Member Bobarache's Avatar
    Perth, Australia
    Default Clock losing time
    Am having a problem with my clock..... every couple of days when I get in to the car in the morning the clock has reset......trip info, L/100km and km to empty is still ok but the time is way out.
    Battery is only about a month old and connections look good....anyone have any idea what the cause could be ?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I've had this happen 3 times on my 2.2DTi SRi, in the 7 months I've owned it. Since setting the clock to auto-adjust, it's never happened again
    Worcs/Staffs/Westmids (ish)
    Issue with a voltage regulation cct maybe?
    When you start the car, there's a sharp dip in voltage from the battery (perfectly normal). The clock will be supplied from a voltage regulator of some sort (might even be part of the clock though), which ensures it's getting a constant supply voltage (probably standard CMOS or TTL voltages between 3.3v and 5v), there would also be a large value capacitor on the lower voltage side, which discharges when you start the car, thus keeping that voltage up to prevent the clock resetting.
    My money would be on the aforementioned capacitor, but if it's part of the clock then your slightly screwed
  1. Changing the clock time
    By bensterzback in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2013, 10:18
  2. TID Clock not keeping time ? and other related issues
    By Dursley in forum Electrical & ICE (including SatNav)
    Last Post: 15th June 2012, 09:53
  3. Adjust Clock/Time Manually after installation of Replacement Head Unit
    By DavieBhoy1969 in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2011, 10:23
  4. Signum has 100k on clock time for service!
    By total_vxl in forum Vectra C / Signum Car Chat
    Last Post: 26th December 2010, 01:10
  5. Changing time on clock without standard sterio in
    By shearzy in forum Vectra C / Signum Car Chat
    Last Post: 7th January 2010, 21:42
https:www.vectra-c.comforumshowthread.php139223-Clock-losing-time
insignia clock losing time
vectra clock loses time
Vauxhall insignia clock not keeping time
Movano clock loses time
vauxhall insignia clock was reset
