Thread: I Smell Petrol
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Default I Smell Petrol
    Had This Ages Ago As Well...Other Day I Went And Put 60 Quid In The Tank...Now The Smell Of Petrol Is Hellluva Strong...Just As I Step Out Drivers Door...
    Aint Leaking Nowhere..
    Could It Be Fuel Filter ?
    Regular Member themarbleman's Avatar
    sussex
    My wife had the same problem on her Xsara Picasso,the garage could not find it but i did !!!!!!!
    On the filler tube behind the wheel liner is a vacuum pressure tube/valve,this had snapped of at the very top hence the smell of petrol...
    The solution....£138 for a complete assembly or cut back the tube and reglue with superglue...Problem fixed and that was around 5 mounts ago.
    It could be something very similar...
    Jan 2010
    glasgow
    that would be my first port of call give the filler neck a good look over make sure the tank aint got no leaks is there not vents at the back of the rear bumper? also how is the car running tam? could it be over fueling ? pull the spark plugs and see what like they are
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by hoochydady View Post
    Seems To Be Running Aryt Likes Mate..Dunno Bout The Vents..Or Whether Its Over Fuelling Or No..Its Due A Service..I Got Plugs/Oil/Filter There So Should I Just Pull The Plugs Or Change Them ?
    What Am I Looking For On The Plugs ? lol
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    You checked the fuel filter tam? Its clipped to the side of the tank under rear passenger door.
    Aug 2010
    Dundee-Motherwell
    no checked it yit mate..can nearly smell it aw the time..stronger when am just gettin oot the car
  1. Smell of petrol in car
    By davidj387 in forum Engine & Drivetrain
    Last Post: 2nd July 2010, 07:46
  2. Petrol Smell
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:20
  3. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  4. petrol smell
    Last Post: 22nd November 2007, 19:40
  5. smell of petrol
    By kevinmcm19 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2007, 23:16
xsara picasso petrol smell
