Thread: Slight misfire at idle
    Regular Member Lozza's Avatar
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Default Slight misfire at idle
    Hello all, i have a vectra c 1.8 2003, its got a very slight misfire at idle, ive changed the plugs, cleaned the throttle body and tryed a coil pack off another vectra 1.8 and its still the same, theres no lights on the the dash coming up ever, any suggestion would be much appreciated thanks Lozza.
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Had to get a new battery today £62 from vx as the old 1 had the black light warning and only reading 46%, tested the alternator and that was fine so im happy about that, but theres still the problem with the slight miss, could it be the EGR valve as ive been looking through the forum and therers a few posts about this problem oh and ive just filled up with a full tank and put some wynns injector cleaner in as well, give it clean through.
    The misfire seem to be more when the engine is cold, then when its heated up its not as noticeable.
    Jun 2011
    Brum
    Vehicle : Vectra c
    Trim : SRI
    Engine : 1.8
    Year : 06
    Right ive been driving around now for a few days and the car is running lovely after i put that wynns injector cleaner in, think its down to cleaning the throttle body out aswell, seems to run very smooth now, but! when the the engine has warmed up and standing still just ticking over the revs go down to about 700rpm and i can feel a slight judder.. what could this be? any idea`s would be great thanks (Lozza)
    New Member evilblond's Avatar
    Jun 2011
    Sakarya
    Throttle valve, idling regulator can issue them. First, clean the throttle, then change the idle speed adjuster.
  1. 3.2 GSi slight misfire, need help....
    By TimTay in forum Engine & Drivetrain
    Last Post: 19th August 2011, 11:10
  2. 1.9 CDTi Slight misfire
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2010, 00:19
  3. Poor starting and slight misfire on z22se
    By Nato in forum Engine & Drivetrain
    Last Post: 5th June 2010, 23:55
  4. Slight CDTI misfire
    By GazVXLINE170 in forum Engine & Drivetrain
    Last Post: 2nd June 2010, 17:46
  5. cdti 150 slight misfire! help needed
    By craigz9876 in forum Engine & Drivetrain
    Last Post: 30th October 2009, 11:11
