Thread: Car with spanner warning light
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default Car with spanner warning light
    Hi all.
    Today my car ''technically'' broke down on me today.
    It was all fine until I joined a queue of traffic in the heat (temp gauge @ 93 degrees), then after about 5 mins of queuing, the car/spanner light came on whilst engine running. This then cut the engine about after about 1 minute of pulling away.
    It re-started ok but light still on with engine running, then engine cut out again. This process happened several times and a gent kindly gave me a tow off the dual carraigeway into a layby.
    After waiting about 40 mins, I started the car and light stayed on with ignition, but off with engine running so proceded to get it home. The light stayed off.
    The light currently stays off whilst engine running as I have started it up a few times tonight. Anyone know if the fault could of been self-rectified???
    Would it be worth getting a fault code reader or a garage to check out out in case this happens again???
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Quote Originally Posted by Casper85 View Post
    Hi all.
    buy your own fault code reader...it would be cheaper than paying a garage to read the code....
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by robengland9 View Post
    Search eBay for "U480 code reader"
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    I drive a 2.2 Sri Direct Vectra (06 plate), would this U480 reader work for my car ok???
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Can't see why not. I've never tried it on that model, but it works on my 2002 2.2DTi SRi, and my 2006 1.9CDTi SRi. Also used it to read codes on an X reg Astra 2.0 DTi, and a 2005 Corsa 1.4.
    HTH
    Essex
    Casper I had the same problem with my Vectra 2.2 06 plate.
    I had the same symptoms as your car, i did some digging on this site and pin pointed the problem down to two possible problems. Either a faulty high pressure fuel pump or a faulty pressure fuel regulator. A member on here stated that if the car cuts out it will be the pressure fuel regulator if the car goes into limp mode it will be the fuel pump.
    Vauxhalls did a recall on all Vectras 2.2 models to have an upgraded pressure fuel regulator fitted. I phoned up my local Vauxhall Garage they confirmed the recall I had my fuel regulator changed and it has sorted the problem. The spanner light now also extinguishes on stage two of the ignition meaning there are no faults stored. I have been in slow moving traffic and all is now fine and it didn't cost me anything to fix.
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Mileage : 54600
    Quote Originally Posted by rocket999 View Post
    When I bought the car 4 and a half years ago, I didn't get any paper work about this recall. Only recall my car has had (that I'm aware of) is for a handbrake modification. I shall ring up my local Vauxhall dealer 1st thing tomorrow and see if anything can be done. For a very long time the spanner light has stayed on with ignition until engine starts, but according to the handbook in the glove box it should only come on briefly with ignition.
  1. Car with spanner warning light
    By Handles Sri in forum Engine & Drivetrain
    Last Post: 26th October 2012, 14:52
  2. Spanner Warning Light
    By TAL in forum Vectra C / Signum Car Chat
    Last Post: 20th June 2011, 18:13
  3. Spanner warning light
    By olearysp in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:41
  4. car and spanner warning light
    By paul515 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 01:49
  5. Car with spanner warning light
    By DennisTheMenace in forum Engine & Drivetrain
    Last Post: 23rd March 2007, 07:47
vectra car with spanner warning light
vectra warning light car with spanner
car with spanner warning light vauxhall vectra
https:www.vectra-c.comforumshowthread.php139197-Car-with-spanner-warning-light
what does the spanner light mean when you put your ignition on vauxhall vectra c
vectra c car spanner warning light
car with spanner warning lightspanner and car warning light on vectra cbrake vectra car and spannervauxhall vectra car with spanner lightcar spanner light vectra dtivauxhall car with spanner warning lightvauxhall vectra warning lights spannervectra 2007 warning light car spannercar and spanner alert light on vectravectra warning light with ignition onvauxhall vectra warning 58 lights spannercar with spanner warning light vauxhall vectra 1.8vectra c warning lightswarning light vauxhall signumvauxhall vectra diesel car and spanner signVauxhall vectra spanner warning light before ignition Vectra c 1.8 car with spanner warning lightvauxhall vectra 2.2 cdti spanner light came onvectra warning lights
