Thread: How to remove plastic plate underneath engine?
    Devon
    Default How to remove plastic plate underneath engine?
    Big shock on motorway today when that plastic plate underneath the engine came loose... Could fix it temporarily on the spot but now wonder if it is easy to remove completely myself or should I leave that to a trained mechanic?. Anyone any advise? Obviously, I need to get another one from vx (any idea about price?).
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Quote Originally Posted by mvdg View Post
    why would you need to get another one? ..if its just came loose then its only a few screws...or is it broken
    Devon
    One part snapped off (driver side), passenger side might be repairable. Will have a look tomorrow morning to see if it isn't as bad as it first looked. Thanks!
    Nottinghamshire
    The centre hatch is held on by 5 large fasteners, and the undertray itself is held on by 10 Torx bolts (8 underneath and 1 in each wheelarch).
    If it's just the centre catch that's loose, it's probably because the screws weren't tightened up enough - you have to turn them until they pop into place otherwise they just come loose. If it's the whole undertray that's loose, it might be some of the Torx bolts or they've got pulled through the plastic of the undertray.
    Devon
    Thanks, yes, you were right. Easy job, needed some new self tapping screws and washers but it sits nice and tight underneath the car again, thanks!
  1. how to remove plastic piece from seats
    By antowens in forum General Chat
    Last Post: 10th December 2012, 00:34
  2. How do I remove the plastic door pillars?
    By Innes in forum Styling
    Last Post: 7th September 2011, 14:49
  3. Replies: 3
    Last Post: 14th August 2009, 16:57
  4. 03 plate Signum V6 Design plastic sills ?
    By mammix2 in forum Styling
    Last Post: 28th July 2009, 15:16
  5. How do you remove the plastic inserts by the Fogs ??
    By DeanF in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2008, 13:10
