Thread: turbo noise
    Aug 2007
    peterborough
    Question turbo noise
    since getting my exhaust done, from front cat thats mounted to the manifold, 2.5 inch exhaust, then 2 inch from y section.
    ive notised the turbo sucking in louder and the dumping of pressure is more crisp, is this usual, exhaust is real nice with the work spot on.
    also might be just me but when i give it some, it doesnt push me back into my seat as much... might be same not sure.
    what you guys think? cheers
    Worksop
    probably losing back pressure?
    Aug 2007
    peterborough
    is that due to the increase of exhaust? i got it done as planning to get it remaped soon,
    Worksop
    teah if its massive diameter u will loose back pressure
    Regular Member accveccysriturbo's Avatar
    Jul 2010
    west mids
    Doubt it will be back pressure issue. There are guys on here running stage 1 with 3" systems.
    The original bore diameter on my 2.0T down pipe and main sections is 2" (I measured it when I got it home) so it's only increased it .5" over standard.
    Mine appears fine picks up etc etc intact I would say it appears to spool up quicker.
    Will see when I get it on the rollers lol.
    Aug 2007
    peterborough
    yer prob just me adam, u know when you do something new to your car you look for faults/noises.
    defently the turbo spools quicker, and a crisper dumping sound.
    you looking forward to the roller session? where you doing that at?
    Jul 2010
    west mids
    Down at high tech motorsport where it was done first time. I only use one dyno as they all give different readings so I can judge any gain or loss accordingly n not blame different dyno.
    I'm interested to see what it makes. Last time I was there I had a pre map run at 169 wheel bhp and after was 181 wheel bhp. I'm actually after more trq lol.
  1. 2.2.dti turbo noise
    By andy_richmond in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2012, 12:28
  2. 2.0 turbo noise
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 28th August 2012, 21:42
  3. Turbo noise
    By danman487 in forum Engine & Drivetrain
    Last Post: 24th July 2010, 14:38
  4. Turbo noise?
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2008, 23:20
  5. Turbo Noise
    By phildews in forum Engine & Drivetrain
    Last Post: 26th April 2007, 23:14
