Results 1 to 10 of 14
Thread: Bulb Warning Light...
    Regular Member Ross-SRi's Avatar
    Merseyside
    Default Bulb Warning Light...
    Somebody might be able to help me out with this...
    I've never had any of the warning lights come on in this car, but now I've got the orange bulb warning light above the clocks and on the information screen it's saying 'Parking Light'. The thing is, my parking lights are fine - I've checked them.
    Any idea what's causing this or how I can sort it out?
    8 Post(s)
    Which parking light? Front or rear?
    If rear, have another look as there are 2 bulbs per side in the light cluster. One is also a brake light. If the upper parking light fails, then the lower parking light takes over the role of parking/brake light.
    It could also be a bulb is on its way out. Although not blown yet, the resistance changes enough to trigger the fault light.
    Merseyside
    Cheers, I'll have a good look at it now That makes sense.
    scottish region
    yes should be the rears then
    8 Post(s)
    Quote Originally Posted by Ross08 View Post
    And?
    Regular Member Deann's Avatar
    Mar 2011
    England
    I also have this problem at the minute?
    'Parking Light' but all of my bulbs appear to be fine?
    My passenger side rear fog light doesn;t seem to be working even when I put working bulbs in its place?
    Jul 2011
    kent
    The back left fog circuit isn't used.
    8 Post(s)
    Double check the rear lights as there are 2 each side.
    One is also the brake light, but if the tail/brake light fails, the other tail light then becomes the tail/brake light instead.
    Mar 2011
    England
    I don't quite understand?
    Surely if it was a brake light failure it would said brake light and not parking light?
    I will go out and check now
    8 Post(s)
    Quote Originally Posted by Deann View Post
    Not if it was the lower of the two tail lights, which becomes the brake/tail light if the upper one fails.
  1. bulb warning light
    By woodze in forum Electrical & ICE (including SatNav)
    Last Post: 13th May 2012, 12:24
  2. Bulb warning light.
    By telstar in forum Vectra C / Signum Car Chat
    Last Post: 24th July 2011, 20:43
  3. Bulb warning light
    By corm in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2011, 19:03
  4. Bulb warning light
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 00:13
  5. bulb warning light
    By nufckev in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2008, 20:29
