View Poll Results: how many turns does you engine make before firing up? (not key turns)
Voters
86. You may not vote on this poll
  • 1
    31 36.05%
  • 2
    29 33.72%
  • 3
    17 19.77%
  • 4
    8 9.30%
  • 5
    2 2.33%
  • 6 or more
    1 1.16%
Multiple Choice Poll.
Results 1 to 10 of 20
Thread: how many times does your.....
    Regular Member bunsen1's Avatar
    suffolk
    Default how many times does your.....
    ignition take to fire up the engine on a vectra diesel, mines a 1.9cdti sri 150 but general diesel question, post your variant if you would like to
    i do not mean the turning of the key
    reason i ask is i changed my glow plugs and its still taking 2 but mainly 3 times before it kicks in, is this right? i know petrols are much quicker but thoughts appreciated
    also being warmer will it affect it in general as the glow plug is not used as much???? noob i know before anyone pipes up lol
    ireland
    if the engine takes a few crank overs to start remove induction pipe and spray alittle bit of wd40 around the butterfly vlave then fire her back up
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Without going out and trying, mine goes on second or third as well, neve thought anything of it. Fires up a lot faster than the lad across the roads motorbike lol
    suffolk
    Quote Originally Posted by tugger434 View Post
    ok, but im not sure i know where you mean?
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Quote Originally Posted by bunsen1 View Post
    I use to start mine when glow plug symble goes out and it was starting after engine turned over 2 or 3 times.... I found if I waited another 2 seconds it fires instantly..... I think its due to the fuel pressure from pump needs more time to build pressure.... give it a try ....like to know if its same with yours?
    suffolk
    will give it a a few trys to find a pattern
    suffolk
    anyone have any other ideas about speeding it up, i notice in the poll a most are 1 and 2-3 joint
    what do you guys with votes of 1 think?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    The glow plugs wont be in use in this temperature. I put the key in, don't even wait for the glow plug light and crank it straight of and it fires almost straight away, the engine may turn over once but its pretty instant for me. Its a Fiat by the way but the same engine as the 120 Vecs. What has transformed it is the battery, I put a higher spec one in than was fitted at the factory and even in the winter it now fires brilliantly.
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    mines starts very well 2 turns, very rarely see the glow plug light on dash. 2.2dti
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Mine always fires up within 2 or 3 turns. Always first time. Even on a freezing morning without using the glowplugs
  1. different 0-60 times??
    By paul4400 in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2010, 13:40
  2. 0-62 times
    By ACSRITURBO in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2010, 19:24
  3. Sad times
    By Durk in forum Northern Ireland (RO - Vacant)
    Last Post: 14th March 2009, 10:04
  4. 30-70 times.....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2007, 16:25
  5. 0-60 times.
    By Caterman in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 13:01
