Thread: Rough idle after timing belt change
    West Midlands
    Default Rough idle after timing belt change
    Hi - wondered if I could get a point in the right direction with this.
    I changed my timing belt yesterday (Z18XE) and all went well, turned the engine over twice after adjusting the tensioner and then twice again just to be sure before I put the covers back on, and all the marks were still in the right place so I'm happy that the valve timing is OK.
    But today when I start it, the idle is a bit 'chuggy' and it feels like it's running on 3. It's like a regular miss, not random.
    It revs OK and I just took it round the block and performance felt OK too.
    It's showing a fault through the 'pedal test' - 0110 - which I think happened because I ran it with the air flow meter disconnected as a test (which didn't make any difference).
    I've checked the connections that I can see and it looks fine, what else can I check?
    Cheers!
    West Midlands
    Update - I left the battery off for 1/2 hour and it's still showing the same 0110 code now, is that consistent with the ropey idle?
    Nottinghamshire
    Sounds like it might be. Do a search of '0110' on here and read through the threads it turns up like this one.
    Regular Member kentish_bloke's Avatar
    Sittingbourne, Kent
    Vehicle : Insignia
    Engine : 1.8 VVT
    Mileage : 42800
    i had my timing belt done on my Z18XE last year & noticed a little 'chug' every now & then when idling (didn't do it before), but otherwise it's been absolutely fine. The guy who did my belt said that each cam was a tooth out. both the mechanic & the service manager said how quiet it was when idling.
    West Midlands
    Duh - well it turns out it was my own fault. After running out of ideas I stripped it all down again and found the exhaust cam out (retarded) by one tooth.
    idling lovely now!
    I can't really understand why that would cause a regular miss at low revs yet run well at higher revs...but then again I don't really care.
  1. Gsi timing belt change
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 1st February 2012, 13:30
  2. timing belt change
    By sri matt in forum Engine & Drivetrain
    Last Post: 3rd January 2012, 18:25
  3. when to change the timing belt
    By pmitchell in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2011, 12:42
  4. Timing belt change
    Last Post: 9th May 2008, 22:58
  5. Timing Belt Change...
    By C19_CJB in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2006, 12:16
car running funny after cambelt change
my diesel engine idle and shut off after i change timing belt
changed my timing belt on z18xe engine now its running lumpy
why would you get a rough idle after a cambelt change
vauxhall z18xe incorrect valve timing
z18xe noise after timing belt
changing a z18xe cambelt
vauxhall running bad after vvt pully replacement
vvc rough running after belt change
opel insignia run rough idle
vectra z18xe timing marks
diesel engine lumpy after cambelt change
diesel engine lumpy after timing belt renewal
engine idle slightly rough after belt change
vauxhall zafira timing belt change
car sounds bad when idle after cambelt change
