Thread: intake manifold/swirl valves
    Edinburgh
    Default intake manifold/swirl valves
    My linkage has fallen off however the only reason I know is I looked. No EML, no limp mode etc. Should I just ignore until it actually becomes an issue? is it likely to?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Its probably been off for ages and won't have affected performance. Not an immediate threat but left untreated the bearing of the flaps could collapse and they could fall into the engine. Don't know how long I drove with mine off though but the manfold was in a sorry state.
    In that time it may gradually start to cause a boost leak to occur as the flap bearings were allowing the air/oil/soot to escape hence the mess of the manifold.
    Gazza4
    Edinburgh
    how much is a new manifold roughly? Not what i wanted to find the day after spending £700 on a new DMF
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by Big Knox View Post
    The manifold and swirl bar (yeah they're seperate) are about £185-£200 in total for the parts, and another £300 to have them fitted as it's a big job.
    Edinburgh
    think I'll be trying glueing on a some rubber washers first then lol
    Regular Member farley2708's Avatar
    antrim n.ireland
    why not give it a go,i did when i discovered my bar lying on its side,filed down about 3mm,glued on the washers,still in place today
    May 2006
    scotland
    Here is my thought for today, mine I think is losing a little boost as there is now crap accumulating around the holes, bar still connected and working. However, if I was in your situation, and your car is running ok, could it be possible to try and seal the three pots (not the one that is motorised) with some sort of sealant of try and reduce the gas escaping? Or would this simply be farting against thunder because without stripping it all down, you could never acheive a seal on any of the pots?
    Regular Member bunsen1's Avatar
    suffolk
    manifold is on ebay from vauxhallpartswarehouse, i paid £165 with delivery i think, updated version (with obviously the bar attached
  1. Swirl Valves......
    By signum_1.9 in forum Engine & Drivetrain
    Last Post: 5th July 2012, 19:16
  2. Swirl valves
    By MattHD in forum Engine & Drivetrain
    Last Post: 18th April 2011, 12:45
  3. swirl valves
    By bridge_eee in forum Engine & Drivetrain
    Last Post: 27th September 2010, 14:36
  4. swirl flaps intake manifold
    By galway1 in forum Engine & Drivetrain
    Last Post: 6th May 2009, 21:40
  5. intake manifold/swirl actuator
    By John-joe in forum Engine & Drivetrain
    Last Post: 13th August 2008, 14:09
