Results 1 to 10 of 13
Thread: warm aircon
    Edinburgh
    Default warm aircon
    Just replaced my aircon condenser and regassed using one of the DIY things from Halfrauds. Still blowing warm air. It looks like it is holding pressure though now. Do you think something else is wrong too? if so what? or is it just DIY kit is rubbish?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    are these diy kits easy to do? what does it do? does it re-gas the aircon?
    looks like your not having much luck mate with your motor are you,
    falkirk
    diy kits are crap and wont work to refill system dont work well as even a top up
    Edinburgh
    Quote Originally Posted by chris1804 View Post
    Lol well I figured since I had decided to keep the car and fork out for a DMF I might as well sort all the other niggles.
    The DIY kit is easy to use, it just plugs into the low pressure port near the front of the engine bay. Would be even better if it made the aircon cold too though.
    PS fancy coming and setting fire to my vec? lol
    scottish region
    only about £20 to get it gassed so would not touch the diy kits
    falkirk
    kwik fit are cheap for air con and they do leak down test to check for leaks etc
    Edinburgh
    where does it for £49, where does it for £20?
    I like the fact kwikfit say that unless it cools your aircon there won't be a charge.
    West
    Ian,
    my aircon died from turning it off over winter Doh... i'm always telling folk you have to run it at least once a week what ever the weather or it will leak through the seals.
    my own fault for forgetting to turn it back on (climate from eco)
    well i found a place today local to me who regassed after pressure testing & adding a dye all for a cash price of £40.
    it's been icey inside all afternoon while travelling around for work... trouble is my latest issue:
    my outside temp sensor has been moved (clearly while having the dmf work) & is now over reading... damn it!
    my guess is it's sat too near the engine & not behind the bumper as it was prior lol... i will investigate at the weekend
    Edinburgh
    Probably dangling against the aircon condenser and getting heat radiating from engine.
    West
    yeah I'm hoping so! grr... didn't realise until today & the temp was showing 38*c, it was warm out but not that warm lol...
  1. Warm aircon
    By DannyboySRI in forum Electrical & ICE (including SatNav)
    Last Post: 31st August 2012, 15:44
  2. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  3. to warm
    By graham a in forum The 'Off Topic' room
    Last Post: 28th June 2011, 20:33
  4. A bit warm
    By MattW in forum The 'Off Topic' room
    Last Post: 25th July 2008, 21:12
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
