Results 1 to 10 of 19
Thread: mystery coolant leak
    Edinburgh
    Default mystery coolant leak
    Chaps,
    Anyone know any tricks for finding coolant leaks? I have to keep topping mine up and yet I cant find where its getting out. There's no wet bit on the drive and no steam rises from the engine. I'm pretty sure its not the head gasket. The oil looks fine and coolant free. Its doing my head in.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Take off the header tank and check the back for a small crack. Few posts on this now. Dont worry only £19 or so from the dealers if it is split mate.
    Edinburgh
    thanks will have a look
    West
    leaking header tank would also be my first look
    Regular Member sheepish's Avatar
    Yorkshire
    Try checking at night by torch light. When the air's cooler any steam will be more obvious and show up in the torch light.
    ...and it'll give the neighbours something to talk about.
    north east
    You used to get crystals forming at the site of the leak with the old blue coolant dont know about nowa days though.
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Check exhaust as well, slight blow in HG could blow steam through.
    Edinburgh
    don't see a crack on the reservoir.
    Interestingly the coolant level hasn't gone down while the car hasn't been driven. So it appears to happen when engine is running. I looked at water pump and can't see any signed that liquid has been near the outside of it.
    Any ideas? very frustrated.
    Edinburgh
    I think the hose pictured below might be the cause of my coolant leak. however it doesn't seem to leak all the time. Is the cable beside it controlling a valve or is it a sensor?
    Second picture to make location clearer.
    Thanks.
    Aug 2010
    Leeds
    Default Pressure tester.
    You can make your own pressure tester.
    You need a tyre valve and a coolant cap, drill hole in cap for stem of valve to fit through and fit valve.
    Pump to no more than 13 psi with foot pump and spot your leaks.
    It works ok some caps have a valve under the cap remove this the best you can as it's only for a testing purpose and to release air remove valve core.
  1. Coolant leak
    By Vin in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 22:49
  2. Coolant leak
    By DNS in forum Engine & Drivetrain
    Last Post: 7th January 2010, 13:10
  3. Coolant leak!!!!!!!!!!!!!!!!!!!
    By gregc in forum Engine & Drivetrain
    Last Post: 14th August 2009, 09:17
  4. Coolant Leak???
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 19th January 2009, 05:46
  5. 2.0T Coolant leak
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 22:53
vectra vxr coolant leak
vauxhall vectra vxr coolant leak
insignia inlet manifold coolant leak
