Thread: door fault
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Default door fault
    when i open the rear drivers side door, the door open indicator on the dash comes on showing me the doors open but then it goes off?
    dodgey contact switch me thinks but where is it so i can give it a clean
    al.
    May 2008
    Tyneside
    Contact is within the dooe lock mechanism, not sure if it is accessable to clean. HTH
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    Quote Originally Posted by tridley View Post
    damn...
    has anyone had to clean the contacts and how did they do it
    al.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Still have issues with my passenger front from time to time. I just give a good healthy spray of dub d and give the latch a wiggle. Seems to help. Sure some one on here said to cure it properly you need to change the whole mechinisim.
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    cheers tim... il give it a blast later
    al.
  1. Driver door fault
    By oodjsparkiedeeoo in forum Vectra C / Signum Troubleshooting
    Last Post: 21st August 2011, 14:53
  2. Replies: 15
    Last Post: 9th July 2011, 22:19
  3. Replies: 9
    Last Post: 15th October 2010, 17:57
  4. rear door electrical fault
    By sla002 in forum Electrical & ICE (including SatNav)
    Last Post: 18th February 2010, 19:44
  5. Recycling Irmscher Door Sill Plates and Door Pillar Trims
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2008, 19:08
