Thread: help please changed alternator belt now getting loud noise
    Regular Member deano1's Avatar
    leicester
    Vehicle : Vectra estate
    Trim : Sri xp2
    Engine : 1.9 cdti 150
    Mileage : 100000
    Default help please changed alternator belt now getting loud noise
    hi due to getting a small squeal on tick over i replaced the alternator belt now i get a very loud squeal when you rev the engine.
    the belt came from my local motor factors
    wish i had left it aloane lol...
    Regular Member sheepish's Avatar
    Yorkshire
    Did you replace the tensioner?
    I've only replaced this belt on a ford focus and the noise was actually coming from a failing tensioner. It may be the new belt is putting more stress on it (being new and not stretched).
    ...just a thought
    West Sussex
    Quote Originally Posted by deano1 View Post
    Certainly sounds like the tensioner, but if the belt is not a VX part it could also be the culprit. Personally (especially with the benefit of hindsight) I would change the tensioner as well as the belt and put a genuine belt on.
    PRESTON
    Genuine belt all the way, the factor supplied belt seem to be made from a far harder, smoother material than the VX ones. First job is to put a VX one on , clean the crud off the pullies and see how that goes.
    Regular Member robengland9's Avatar
    Feb 2011
    london
    sounds like belt slipping due to tensioner not working properly..... have you checked tensioner...it should take alot of pressure to move?
  1. Replies: 3
    Last Post: 15th August 2012, 14:20
  2. Loud sucking noise
    By D33ler in forum Engine & Drivetrain
    Last Post: 25th March 2012, 12:51
  3. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  4. loud whine cam belt area????
    By taxidriver50005 in forum Engine & Drivetrain
    Last Post: 6th March 2008, 20:10
  5. Loud knocking noise...
    By haegwani in forum Suspension, Wheels & Brakes
    Last Post: 15th June 2007, 07:54
loud squeal when reving vectra
vectra c engine noise gets louder when revving near belts side
insignia belt squeal
https:www.vectra-c.comforumshowthread.php139098-help-please-changed-alternator-belt-now-getting-loud-noise
vauxhall vectra aux belt noice
vectra c 1.9 auxiliary belt noise
insignia squeaking. gets louder when revving
vauxhall insignia grinding from auxiliary belt area
changed alternator belt now car is loud
vectra c alternator belt noise
