Thread: Drivers Door Lock not working
    May 2011
    North Yorks
    Default Drivers Door Lock not working
    Hi, I have just bought a 04 cdti sri and the drivers door lock button does not unlock/lock the central locking (although it does the boot ?)
    Also when I lock all doors using the passenger door lock button and open the drivers door via the handle it does not pop up the lock i have to do this manually, is this right, my MG ZTT worked this way !
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    if your using the key to open the door yes its right the key will only open the drivers door
    May 2011
    North Yorks
    thanks chris, but I am sat in the car at the time. under the window controls is the door lock button except mine does not lock anything but unlocks just the boot..... the passenger door lock button locks/unlocks all doors and boot though.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Sounds like a faulty door module..
    May 2011
    North Yorks
    easy or cheap to fix??
    thanks Ken
    Engine : 2.2 Direct
    Easy yes... cheap no.. as the door module needs to be coded to the car...
    Engine : 2.2 Direct
    But try to clean the different plugs first.. to rule out them..
    May 2011
    North Yorks
    is there a How2?
    for info the Boot is released by pushing the button but not the doors....
    Engine : 2.2 Direct
    no how2.. burt you can see the door module when you take off the doorcard.. have you tried cleaning the switch..
    May 2011
    North Yorks
    will try that tonite and see if it makes a difference.
  1. drivers door lock
    By eddy b in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2011, 06:24
  2. Drivers Door Lock Switch Help
    By UltraVec in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 16:31
  3. De-lock Drivers Door...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:43
  4. Drivers Door lock problem
    By r3m0dul8 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 10:43
vectra c drivers door lock switch doesnt do anything
