Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: 2.2 dti steinbauer pbox help
    Sep 2010
    Dumfries, Scotland
    Default 2.2 dti steinbauer pbox help
    So i just got a second hand unit from Germany, all excited so went to fit it. Followed the instructions, seemed straight froward and joined all the wires. Now though the car won't even start, turns over but sounds like it's got no compression?
    Though I'd try with the box switched off as the setting may be too high. Same thing wont start.
    Hmm what did I do wrong? I cut the pump wire and used connectors, rather than soldering direct to the wire, could that be it? Please don't tell me my pump is now knackered as I will cry...
    I'm going out to solder the wires now, but any help and advice would be greatly appreciated, as I'm starting to panic - work tomorrow and no car - oops...
    Cheers,
    Larann
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    John robertson has same box, I'm sure he will be able to help
    Irmscher Insignia CDTI 130
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Hi, have you maybe blown a fuse? Start with the easy things first no need to panic..............................yet.
    Sep 2010
    Dumfries, Scotland
    pulled the fuses and they all seem ok, even the big ones, not checked the wiring diagram to see which one feed the fuel pump, but I'll take a look and see if its gettng power out.
    Soldered the wires and still no go. Even with things back to normal it doesn't want to start.
    Depression is kicking in
    Sep 2010
    Dumfries, Scotland
    Still no joy on this, gonna leave the battery disconnected for the night, see if it resets anything. Then if that don't work I'll need to borrow my m8's diagnostic machine and see what fault codes are registed (yep the spanner's appeared).
    The engine spins over but it just sounds flat and doesn't want to fire, so I'm guessing no fuel because that's what I've been working around, but I just can't grasp why it's not working as all I've done is unplug things and plug em back in.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Did you connect it to the correct pump wire the first time you tried it?
    Sep 2010
    Dumfries, Scotland
    the one at the front as the instructions tell you, but it's kind of at an angle if you know what I mean. If it was on the wrong one would it blow somehting?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It could well do. Iirc you have to remove a multi plug to gain access to the wires, did you plug it back in?
    Sep 2010
    Dumfries, Scotland
    Yeah, unpluged the egr and then the multi plug on hte righthand side of the pump, all plugged back in. Even double checked to see if I'd accidently bent a pin, and then sprayed them with wd40 incase i'd disturbed a dry pin.
    I just hoped I've not knackered the brain, but it's starting to look more and more like that, but then I also can't believe it's that delicate. I kind of though also that the car would run if the brain was knacked but wouldn't fuel properly with any throttle etc?
    Sep 2010
    Dumfries, Scotland
    Plugged in the diagnostic machine (W.O.W.), and it's chuffing spitting out a P0606 code, so an ecu fault, great.
    I still can't really believe I've done something to cause this, but then it can't really be coincidence either!! Kind of thinking the pbox may have been knacked and possible sent some kind of surge etc to the ecu?
    So what to do next, where the best place to send the unit to?
    Cheers for any advice, and everyone for their help so far.
  1. spotted this on ebay (another steinbauer pbox)
    By FLOB in forum The 'Off Topic' room
    Last Post: 5th December 2012, 02:16
  2. Steinbauer box
    By VectraElite 2.2DTi in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2011, 19:45
  3. Steinbauer Tuning Box 2.0 & 2.2 DTI
    By Paddy2bsure in forum Parts for sale
    Last Post: 7th June 2009, 10:45
  4. PBox Install
    By MJED in forum Diesel Engine related
    Last Post: 2nd August 2005, 08:11
2.0dti steinbauer
steinbauer help page
