Thread: dashboard lights not working - help please
    Regular Member Ian's Avatar
    York
    Default dashboard lights not working - help please
    I realise that this inst a vectra-c issue, but some members on here may well of owned one of these and may have come across this problem, so as well as posting on an astra site, I thought I would post here and ask for some friendly advice from the friendly Vec-C crew.
    My mate has a 53 plate Astra 3 door 2.0DTi SRi and has found a buyer for it.
    The only thing wrong with it is the lights for the instruments and dash arent working. They started to flicker a while back and then started to go off, but with a firm wallop to the dash came back on. Now they dont work at all.
    We are going to attempt to fix this, thinking a loose connection somewhere is to blame.
    Has anyone had the same/similar problem and if so where was the fault? I reckon its either behind the instruments or at the light switch, but could it be anywhere else?
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Not quite the same make, but I had this problem on my wifes Sierra a couple of years back. The only cure was a new dashboard so i sold the car to the scrappy instead and he charged me £25, the cheek of it.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by Ian
    Just a thought..is it not still under the 3 year Vx warranty if it's a 53 plate?
    has it got the dimming switch for the dashboard lights found under the headlight switch??
    the resistors in them break down and cause the lights to fail, and a whack will normally fix it for a short while. if that is the case, then the only longterm cure is a new lightswitch block..
    or is it ALL the dash lights including the heater/stereo backlighting?? that is via the headlight switch as well
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    I could not be bothered to change the headlight (and dimmer) switch in the 96 Vec B (or was it the Calibra?) and as Mark says I kept banging the dashboard to keep interior lights on. I got P1ssed of with this eventually and fitted a new switch unit – no probs after that (you would have thought that Vaux would have re-engineered the weakness).
    Regular Member rorycarz's Avatar
    Dec 2005
    AYRSHIRE SCOTLAND
    I Had A Proble With Mine (03) The Needles Started To Drop & The Warning Lights Came On . The Cause On Mine Was Bad Connetion At Abs Plug Under Bonnet Behind The Battery Hope This Helps
    Rory,
    this is an astra question from Ian, not a vec one..
    no canbus on them.. and a better system
    the failing dashboard dimmer is as old as the hills.. been swapping them since the early 90's.
    Regular Member Madgunner's Avatar
    Worrying bout nothing..... Cause worryings a waste of my f***ing time!
    Hi mate I take it you mean the dash illuminations lights- if so I know it's not the same but had a vectra b 150 sri & the bulb on the right hand side done the same flickered on & off for a little while then went out all together. I took the dash out & replaced the bulbs with blue led one's they worked fine for a while & i changed my m8's dash etc with blue bulbs too. These failed in the dash after a couple of months in mine & my m8's. I put the white bulb's in & my m8 who bought my vec b of me has had no probs since. I would take the dash clock out & replace the bulb m8 its an easy enough job to do...
    York
    Cheers guys, I've had more replies off this site than off two astra sites combined!!
  1. Dashboard not working.
    By Last Turkey in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2015, 19:42
  2. Cruise Control dashboard light not working
    By Weaselbert in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 15:30
  3. Signum dashboard lights and dials not working
    By sjmiow61 in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2010, 22:32
  4. Dashboard Lights
    By acedaz in forum Electrical & ICE (including SatNav)
    Last Post: 25th January 2009, 22:57
  5. dashboard and interior lights not working
    By raymondlhuk in forum Bodywork & Interior
    Last Post: 26th January 2008, 20:21
astra mk5 dasbord not lighting up
vauxhall astra dashboard lights not working
astra 1.7 cdti dash illumination not working
zafira a no dashboard lights
dashboard lights fuse ts astra
opel astra H 2006 instruments light fuse
vectra c headlight switch not illuminating lighting up
vauxhall zafira dashboard lights problem
astra 1999 dashboard not lighting up
vauxhall zafira tourer dash logjts noy working
astra mk4 dashboard light fuse
my dashboard lights dont work on my astra
dash lights not working holden astra
opel astra dash lights not working
astra h dash lights not working
vauxhall astra no dashboard lights
vectra c instrument cluster illumination
dash board of a Vauxhall Astra 5th Generation not working
Astra twintop dti no dash lights intermittent
opel corsa b dashboard lights
vauxhall vectra : no instruments working or illuminating. HELP
vectra c dachboard light problem
opel astra g insrument panel not illuminated
insignia dashboard light not working
