Thread: Drive shaft came out of the gear box, should I be worried?
    Regular Member sheepish's Avatar
    Yorkshire
    Default Drive shaft came out of the gear box, should I be worried?
    Hi all,
    I changed the offside hub on my 52 plate Vectra C at the weekend, also changed the cv boot and in the process the drive shaft came out of the gear box. It went back in with a positive clunk, should I be worried, have I damaged anything?
    I did 75 miles in it yesterday with no problem, but the wifes just called saying it's now making a chirping/rubbing noise (that speeds up the faster you go...) coming from the front offside, and it's worse on full lock...
    Any ideas???
    I'm hoping when I get home it'll be something rubbing on the brake disc but I not normally that lucky...
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    What engine?
    Did you loose any gearbox oil?
    Is the noise like a sqealing noise that only appears after the car has been driven for a while?
    Yorkshire
    Hi John,
    It's a 1.8 petrol.
    No, I didn't loose any oil. I read the haynes manual about removing and refitting the shaft and it' says about putting a container underneath when removing the driveshaft to catch the oil. I assumed (probably stupidly) that as I only had the offside jacked up, it had kept the oil in.
    And the noise started after it had been driven a few miles, stopped for 20 mins, then driven again.
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Sounds like the backing plate that protects the bottom ball joint is touching the disc.
    The disc will only touch it when it heats up a bit and the flex of the bearing will press the disc harder onto the shield when on full lock
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    If you used a genuine vauxhall CV boot then it might be that making the noise, they make them out of hard plastic, when i changed mine they made a hell of a noise for a few hundred miles
    Irmscher Insignia CDTI 130
    Yorkshire
    Here's hopin' John :-)
    And Bigmac; no I used a stretchy one, that's how I came to pull the driveshaft out. I used a cone to stretch it over the CV joint and obviously a fair amount of pushing was involved. The cone stuck got stuck on the cv joint and when I pulled it off it just poped the shaft out of the gear box.
    Devon
    72 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by sheepish View Post
    Np i hate them new CV boots
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Thats a good sign, means its in properly. As John said sounds like the brake splash guard touching the brake disc to me too.
    Yorkshire
    Well John, you were right, it was the backing plate touching the disc.
    Many thanks!!!!
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    No problem mate, glad you got it fixed
  1. Drive shaft
    By drummo in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2012, 13:50
  2. drive shaft
    By andy treg in forum Vectra C / Signum Troubleshooting
    Last Post: 5th May 2011, 17:04
  3. Inner Drive shaft boot
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th November 2008, 21:37
  4. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
