Results 1 to 10 of 18
Thread: Dipped headlight bulbs: How do you remove them?
    Regular Member RSV_Ecosse's Avatar
    Falkirk, Scotland
    Default Dipped headlight bulbs: How do you remove them?
    Manual says twist the headlight bulb holder but how?.
    Mine are rock solid and dont seem to want to twist in any direction, I'm concerned I break something here!!!.
    they are firm..
    the spring wire clip is held under two screw heads..it is a tightun as you've found out but it helps if you gently push in at the same time as turning it..
    Falkirk, Scotland
    Cheers m8.
    So do you just turn it?. Or is there a clip that needs undone first?. What way do I turn it?. Just had another go and cant get it to budge, plus cut my knuckle at the same time!!!.
    Right.. got 'desk jockeys' old headlight on my desk in front of me..
    the dipped beam holder is just a spring clip in a folded metal holder..no trick clips to undo or anything..
    if rotates to the left..( anti clockwise) when veiwed from behind..
    give me 5 mins and i'll see if i can get a phone camera photo up for you..
    Hertfordshire
    Quote Originally Posted by Gsi3.2
    Are you going to do any work today ???
    here you are..
    the back of the lamp holder, showing the catch
    the back of the bulb holder showing the 2 spring legs top and bottom
    and someone's fat fingers turning it anti clockwise
    hope this helps..
    Quote Originally Posted by Green Growler
    with this and your towbar...not if i can help it!!!
    Hertfordshire
    There's nothing wrong with my towbar, it's just those dodgy electrics you sold me.
    it's you and your shiney ball cover!!!!
    should have got a shorter car!!
    Hertfordshire
    Lmao
  1. whats best bulbs for dipped beam
    By dodus in forum General Motoring Chat
    Last Post: 22nd June 2012, 16:59
  2. dipped beam light bulbs
    By nelly452 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2011, 00:48
  3. M tech bulbs dipped beam
    By dannyp in forum Electrical & ICE (including SatNav)
    Last Post: 5th April 2011, 22:04
  4. Dipped bulbs
    By mark_647 in forum Vectra C / Signum Car Chat
    Last Post: 6th July 2009, 22:12
  5. Dipped beam bulbs?
    By Humph Backbridge in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2009, 22:07
vectra c headlight bulb turn anti clockwise
