Results 1 to 10 of 21
Thread: MoT dilemma
    Default MoT dilemma
    Prepared the car for its "official" MoT, due 01 June
    Everything looked and tested OK
    Rear tyres are about six weeks old
    Front tyres are about two weeks old (free from Michelin)
    So drove the car to the premises where the MoT will be carried out (closed) and placed it into the parking space
    Walked round the car and there is a MASSIVE nail in the offside rear tyre, which I have obviously picked up between home and the MoT premises, between the tread and sidewall, which is also sticking out by about three inches (but not fouling the bodywork)
    The obvious answer would be to swap the wheel off prior to the MoT commencing for the spare, however this is one of the models that does not have a spare, so that is not a solution
    The next is to order one tyre, but that could be between three and five business days, and to submit the car as it is
    I have submitted tyres before with nails in the tread and received advisories
    However, not one this obvious!
    I have spent some time reading the MoT manual and although it does mention tyre intrusions (nails, etc) I can' find anything definitive that would result in a failure for this
    Any ideas?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    pull the nail out and see if it goes down if not no drama if it does it needs a new tyre anyway so order one
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Due to the fact that it would be irrepairable i'm not sure if it may be a fail this time. As you know repairs within the sidewall area are not deemed to be safe so neither would a hole.
    Could you pick up 2 steel wheels with good tyres just to get the car through?
    Either that or pick up a second hand sri wheel and tyre and use it as a spare after you get the other tyre replaced
    East Midlands
    knock the nail in a bit more,and hope the MOT tester doesn't spot it,if he does you'll have to change it anyway or get it repaired,if it passes you'll get it done cheaper.
    Full Member Big Sig's Avatar
    Paint the head black
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    and then take it to Kwik Fit for the MOT instead.....they'll never notice
    Quote Originally Posted by macdad View Post
    As above, the nail is MASSIVE
    I did push it in slightly and there is no air loss
    However twisting it from side to side and there is air loss
    Pushing it further in, such the head is flush with the tyre, the head will be noticeable
    It is about the size of a 5p piece
    Pulling it will almost instantly end up in a flat tyre
    There will then be a hole about 8mm across
    Equally, as it is on the seam between the tread and sidewall it is well outside the repairable area (otherwise I would have asked them to repair it prior to MoT)
    I don't have access to other similar Vectra wheels at such short notice
    As mentioned previously that is where this car has always been MoT
    On the last one they failed two tyres for very slight buldges (at the time had tyre insurance and they agreed to pay for one of them)
    However, I already had two replacements on order and they were due to arrive the day of the MoT, so gave them an excuse to fail them!
    Equally, they have given numerous advisories but never the same two back to back
    Sickened at this tyre has only done about 500 miles in six weeks, what a waste of £100
    Regular Member azacbr6's Avatar
    Dec 2010
    chesterfield
    Get a puncture repair kit and repair it yourself it only takes 10 minutes to do and it won't be noticeable at all. I had a puncture on the edge of my rear tyre and all tyre shops refused to repair it so I did it myself and now 5000 miles later I can't even find the repaired spot as the rubber plug faded in the tyre.
    Quote Originally Posted by azacbr6 View Post
    There is probably not enough time between the local motor factor opening (that may have such a kit) and the MoT test
    Looks like I will be hitting it with a hammer and hoping it doesn't POP (or more likely explosively BANG) out
    As above, so long as air is not escaping then an advisory should apply (had them before for nails in the tread)
  1. Got A Dilemma
    By Tam80 in forum The 'Off Topic' room
    Last Post: 30th January 2012, 12:44
  2. dilemma
    By fjaimo10 in forum Tuning
    Last Post: 16th December 2011, 11:14
  3. Dilemma............
    By Mrs D in forum The 'Off Topic' room
    Last Post: 25th April 2008, 09:40
  4. Dilemma - What do I do.....
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2007, 21:30
  5. K&N dilemma
    By kitchpoo in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2005, 21:51
