Results 1 to 10 of 26
Thread: Air con noise
    Tayside
    Default Air con noise
    I try to make sure I turn my air con on now and then at least once every couple of weeks to keep the system ticking over. When I turned it on today I noticed that it was making a hissing sound even when running and when I turned off the engine with the air con still switched on you could still hear the hiss while the engine switch off and it gradually went away as the system shut down. The air con itself seems to be working and is cool but just wonder if this hissing noise is anything to worry about?
    Also is it worth having the air con on all the time to ensure that you do not run into problems with it, even though your mpg might go down?
    Barrow In Furness, Cumbria
    The hiss normally means that its low on gas. You need to run the aircon to keep all the seals etc lubricated.
    Sep 2009
    Glasgow
    yep you should have been ok running it as often as you have but, i think the condenser has took a hit and vented your gas out, as said above hissing is a sign of low gas
    Tayside
    Thanks for the replies. Do you think I need to get it checked out and see how it runs over the next couple of days. I have just went out and changed by pollen filter and was surprised how dirty it was, it was really bad and doesn't look like its ever been changed
    May 2006
    scotland
    Mine has hissed since the car was new (just hisses for a couple of seconds or so after the air con is activtaed). 7 years on, the air con is still icy cold.
    Tayside
    Tried the air con again today and is was hissing but still cold. Would you advise leaving the air con button switched on all the time?
    11 Post(s)
    Quote Originally Posted by ChrisVec22 View Post
    Personally yes. You can then control the temperature with the heating knob. Basically what you'll then have is a manual version of climate control.
    May 2006
    scotland
    As said, you could leave it on. It will either stop working i.e. if the gas is leaking it will all leak away if you leave it on, or it will continue working indefinately and continue hissing or it will continue working and maybe stop hissing. If it were me, i'd leave it on and see what happens, nothing to gain or lose really.
    New Member petepete's Avatar
    I had this problem with my car upon getting it back from Pentagon after its first MOT.
    A couple of days later when I turned on the AC for the first time post MOT, I heard hissing; immediately I called Pentagon who asked if I'd bring it in for them to look at. They said gas was escaping and it'd cost me £85 for them to refill it.
    Included with my MOT test was a 'Aircon spring clean'.
    My AC worked perfectly before I took it for the MOT; it is too coincidental that this problem started independently of them servicing my AC. I have contacted Pentagon's customer care and am awaiting feedback.
    What could cause the hissing? Nokiaman mentions that it could be the result of a 'condenser being hit'; is it possible that that happened during the servicing?
    I'm slightly peeved at the way my car works less well than it did before the test, and they want to charge me another £85 to fix it.
    Aug 2010
    Derbyshire
    I'm having my aircon sorted next week.
    It was regassed last year, but never really icy cold.
    The place I bought it from regassed it, on the cheap I guess, never did trust them.
    Anyway taking it to a proper recommended garage, they want it most of the day to do it properly.
    BTW it was working ok ish last week, but now it hisses a lot on start up and never gets cold and coughs and farts and splutters when turned off.
    I do use it weekly, but at the moment it's cooler having the windows open.
    Mick
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
vectra c air con noise
vauxhall 2.0 cdti air con noise
sound from aircon vectra c
