Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: H.I.D/Xenon Conversion - Confused
    Regular Member Deann's Avatar
    Mar 2011
    England
    Default H.I.D/Xenon Conversion - Confused
    Hey Guys,
    I've jsut bought my vectra and straight away I wanted to change my standard bubls to H.I.D's
    In my old astra I had a set of 6000k 35w and thought they were perfect.
    After a bit of searching on the forum, and looking at the how-to I am now totally confused.
    - What have you guys gone for in your vectra's?
    - Does anyone have any pictures of there H.I.D/Xenons from the front and/or beam patterns?
    - What is the 'error code' that I've read a couple fo times in different threads
    - Is there a difference between H.I.D's and Xenons? Which is the ebtter option?
    This is what I've been looking at, what do you think? Should I be looking at something different?
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item4148cb6ae3
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Yea thats the right kit for your car. The error codes is not so much a code but the bulb warning symbol that appears on the dash as the canbus bulb check finds the wrong resistance in the HID bulbs. Warning cancellers solve this as does having the HID setting switched on via Tech2 or Op Com. Even with cancellers fitted you will get strobing from the bulbs, when they are switched off, as the bulb check system does it thing. As before solved by having them fully activated or running with your headlights on all the time. HID's and Xenons are exactly the same thing. If you have a look in my profile and then my garage you will see a picture of my Hids working. The bulb pattern is exactly the same as a normal headlight bulb, there is no distortion as the Vectra has the correct eliptical headlights.
    Mar 2011
    England
    Think I'm going to order some H.I.Ds on Thursday when I get paid.
    I would like to get some 6000k, 35w
    Hopefully they will be easy to fit, and I will find a suitable place to mount the balast.
    I'm also looking at getting some sidelights, these are what I'm looking at on eBay
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...ht_3433wt_1141
    11 Post(s)
    Quote Originally Posted by Deann View Post
    Under the headlight in the recess where the factory fit one would usually go.
    http://www.vectra-c.com/forum/showthread.php?p=1060742
    Full Member Niall83's Avatar
    Nov 2009
    Belfast
    Them led side lights wont show up any errors but will strobe when off and car is running. That didn't bother me as you can just drive with the sidelights on all the time plus you can't really see them strobe during the day unless your looking for it.
    AirBox Mod-Angel Eye head lights-HID 5000k-Colour coded grill-GID to CID-Auto Dim rear view Mirror, Rear Parking Sensors, Signum Fog surrounds, 19" Audi A5 rep Alloys, Eibach 30mm Pro-kit Lowering Springs.
    Mar 2011
    England
    Excellent, I can't decide whether to go for HIDS4U or CARMODSHOP/HIDS DIRECT (these are the same supplier apparently)
    Sep 2010
    HIDS4US buy their kits from CARMODSHOP
    HIDS Direct are a seperate outfit,.. and there's a LOT of stuff on here about them regarding aftersales being poor, me being one customer who would not use them again.
    11 Post(s)
    HIDS4U are overly expensive.....
    Whereas a site with a similar name - (that being HIDS4US) aren't so expensive.
    And as Chewy says, HIDS4US & Carmodshop stock the same products.
    Regular Member disco dan's Avatar
    Apr 2011
    Southport
    got mine from hids-direct only last week, quick despatch and with the cancelors, not even strobing/flickering whilst off. Top quality and the best mod ive done to date.
    Regular Member no1baggiesfan's Avatar
    Jan 2008
    Newcastle
    Vehicle : 1.8 VVT SRi
    Isn't that only on the facelift though Dave ??
  1. Factory Xenon Conversion
    By Maverick in forum Non Vectra C/Signum Album
    Last Post: 3rd January 2012, 14:59
  2. hid xenon conversion kit 4 INSIGNIA
    By jazzy jay in forum Insignia car chat
    Last Post: 11th February 2010, 15:17
  3. hid xenon conversion
    By ftmo in forum Styling
    Last Post: 30th July 2009, 16:53
  4. hid xenon conversion
    By ftmo in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2009, 20:14
  5. Piaa Xenon Conversion
    By LEW1S2006 in forum Vectra C / Signum Car Chat
    Last Post: 7th September 2008, 23:09
how to install xenon hid concersion kit vectrac preface
