Results 1 to 3 of 3
Thread: Dismantling gear lever assembly
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Dismantling gear lever assembly
    Has anybody ever dismantled the gear lever assembly? Haynes states that further dismantling is not recommended however I was wondering if it would be beneficial to do so to clean it up and lubricate it, cheers.
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    6 speed gear sticks are fairly easy to remove down to the balljoint... Pop the gaiter off you'll see 4 torx screws, remove these and use a screwdriver to gently pop a balljoint off on the right hand side and also a little flappy section which acts as a guide type of thing.... Unless you want to take the entire lot out which includes the bowden cables which would mean the whole centre console out job.
    Jan 2010
    Cornwall
    Ok, nice one cheers.
  1. Gear lever,gear selector
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 22nd January 2013, 09:43
  2. VXR Gear lever
    By Derek Mc in forum Styling
    Last Post: 2nd June 2010, 20:19
  3. How to change gear lever
    By hairy31 in forum Styling
    Last Post: 27th December 2009, 20:28
  4. Vectra-C Facelift Gear Stick Assembly & Gaitor. 5-Speed
    Last Post: 5th July 2009, 17:26
changing gear lever asembly vectra
