Results 1 to 3 of 3
Thread: ABS light on after new wheel bearings
    Nov 2010
    Default ABS light on after new wheel bearings
    I have had two front wheel bearings fitted to my 1.9 cdti club. The next day the abs light came on (two lights in fact) Can anyone advise how to reset it.
    Maybe it could be a loose wire or perhaps the garage disturbed something when they fitted the bearings.
    Mike
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    If a garage fitted them take it back for them to fix
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by xf8u39 View Post
    Mike
    They would have had to disconnect the ABS lead from the bearings to remove them. The connector on each side is mounted on the strut. Before taking it back, it may be worth checking that the lead(s) from the new bearings have been re-connected or the wires not obviously damaged. If the latter, get it back to them ASAP and point it out straight away before they get a chance to cover it up in someway then charge you for a repair.
  1. wheel bearings
    By lezSRi in forum Suspension, Wheels & Brakes
    Last Post: 24th January 2011, 23:35
  2. wheel bearings ????
    By MID LIFE CRISIS in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 20:52
  3. wheel bearings
    By scottietlr in forum Suspension, Wheels & Brakes
    Last Post: 1st August 2009, 17:34
  4. Wheel Bearings?
    By andy7807 in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2008, 10:29
  5. wheel bearings
    By blackbeauty in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2007, 21:21
