Thread: rear wheels, rattley noise
    sheffield
    Default rear wheels, rattley noise
    Right I've had the vectra in for a rattling noise from the rear over bumps and come away with some new exhaust mounts but it hasn't solved the problem. It sounds like its coming form the rear wheels and can be heard over bumps and when coasting or decelerating. I've recently had new brake pads on so could it be something to do with that?
    Joss
    Mar 2011
    pontefract
    Trim : design
    Engine : 1.9 cdti
    put your hands on the top of the wheels and give them a good hard tug..
    if they move or you can hear a noise, then its the upper arms.
    al.
    Regular Member rockonoli1's Avatar
    Telford
    Have they got anti-rattle shims in? Have the pads been fitted the correct way round ? Or could be as above worn bushes
    sheffield
    checked the side to side movement but it all seems good on both sides. Is it possible to put the brake pads in the wrong way? what are anti-rattle shims? thanks for all your help so far
    everyone
    sheffield
    Quote Originally Posted by mikeq View Post
    Hi All
    I too have recently been a bit confused changing my rear pads on my 07 vectra,the pads are, as in the picture at start of thread,I put the spring bit next to the piston on the caliper and the pad with no spring to the outside.My breaks work fine now just passed its first mot,BUT...Whenever I go over rough ground or potholes I can hear a rattle from my rear pads,this ceases when I press my foot lightly on the breaks.
    I have checked and double checked but cant see whats causing them to rattle.Ant ideas?
    from this thread
    http://www.vectra-c.com/forum/showthread.php?t=67661
  1. hello any1 help with noise coming from rear wheels
    By yulieb in forum Suspension, Wheels & Brakes
    Last Post: 13th July 2011, 22:09
  2. grinding noise coming from rear wheels
    By pud wayman in forum Suspension, Wheels & Brakes
    Last Post: 21st June 2011, 07:27
  3. knocking noise from rear wheels
    By melvin in forum Suspension, Wheels & Brakes
    Last Post: 20th June 2011, 14:47
  4. rattley something or other
    By Paddyrallyhead in forum Engine & Drivetrain
    Last Post: 2nd November 2009, 21:49
  5. Road Noise / Rumbling rear wheels solved?
    By Raze in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2008, 17:30
