Thread: 2.0 DTi low power/engine momentarily cuts out
    May 2011
    Shropshire
    Default 2.0 DTi low power/engine momentarily cuts out
    My '54 reg DTi 2.0 has started to falter under load and seems to lack power and turbo boost - also there is a different turbo hiss. I have checked round for leaky pipes but found nothing obvious - anyone had anything similar? I suspect it is an electronic/control problem rather than broken turbo, but not sure.
    Vic
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Get the car hot and someone else to sit in it then rev the nuts off it when you're looking around the pipes. I didn't find my split until I did this. If there's a split, you'll see it open up.
    May 2011
    Shropshire
    Thanks for your help - it was the intercooler to turbo pipe was split - car is now as sprightly as ever - probably been gone for a while!
    Vic
    north east
    If it sounds like its hunting / going to stall the crank shaft sensors seem to have a 100 000 mile life span.
  1. Engine Cuts Out
    By bulletproofpanda in forum Engine & Drivetrain
    Last Post: 20th September 2010, 20:41
  2. Engine cuts out
    By Lloydy in forum Engine & Drivetrain
    Last Post: 26th May 2010, 12:52
  3. engine cuts out
    By thedhj in forum Engine & Drivetrain
    Last Post: 7th February 2010, 14:07
  4. Engine cuts out
    By Chippie19 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd August 2009, 09:22
  5. Engine cuts out (1.9cdti150)
    By TimB in forum Engine & Drivetrain
    Last Post: 26th March 2007, 13:20
