Thread: 2.2 DTi spanner light and limp mode only at motorway speed
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Default 2.2 DTi spanner light and limp mode only at motorway speed
    Hi guys.
    Got a bit of a problem with the car, at motorway speeds it keeps kicking into limp home mode. It did it 4 times in a 20 mile run yesterday evening. I can't think of what it is. The boost sensor was cleaned the same day by Drinky (checked the plug too after the second time it went) so I doubt it's that. The strange thing is though if I cane it through the gears hard, it doesn't happen. It only happens when the car is cruising at motorway speeds.
    Any ideas? Bit stumped.
    Cheers.
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    i had the same with my 2.2 dti it hasnt done it since i change the boost pipes for silicone ones cleand the sensor and egr valve.
    Regular Member influencd's Avatar
    Oct 2010
    Eversley
    I was experiencing the same, still did it (though not as often) after I replaced all the vacuum tubes with silicone.
    Symptoms were stopped by taking out the boost sensor and cleaning it again. I've actually just replaced it today. I was using carb cleaner on it and I'm not sure if it was too harsh - it doesn't seem to have been the same since.
    Was getting "boost pressure implausible" error codes.
    I'll try remember to check back if this fixes properly.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Got a knackered pipe that has been well wrapped up but I haven't checked the vac hoses yet.
    EGR will get a clean when I check over the vac pipes.
    Cheers guys.
    Regular Member Innes's Avatar
    Plymouth
    I've still got this but only when going up a hill at 65mph and labour the engine then it goes into limp home mode. My vac and intercooler hoses have been done. I was told on the forum to try adjusting the Turbo Actuator rod as it may be under/over boosting but havent got around to doing it yet. I just tend to change down and give it some welly when going up the hills and it doesnt do it.
  1. 04 2.2direct spanner light and limp home mode
    By ScottyV6 in forum Vectra C / Signum Car Chat
    Last Post: 4th June 2011, 13:45
  2. Spanner Light but no Limp Mode
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 13:07
  3. limp home mode but no spanner light??
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 5th April 2009, 12:22
  4. Replies: 33
    Last Post: 30th December 2008, 19:08
  5. spanner light on 2.2 dti and goes in to limp mode
    By thelad in forum Engine & Drivetrain
    Last Post: 14th March 2008, 21:48
vectra c 2.2 dti spanner light
vectra c limp home
spanner light vectra 2.2 dti
vectra 2.2dti going into limp mode
vectra limp mode
2.2 vectra linp mode
vectra 2.2 dti misfire limp mode
opel zafira 2.2 limb mode
