Thread: Turbo
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    Default Turbo
    Is it possible to fit a turbo to my 2.2 sri direct ?
    anybody know of this being done
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Not without spending thousands of pounds no. You'd be better off buying a 2.0T and selling the 2.2 if you want a turbo car.
    Just for starters, you need turbo, seperate ECU, all wiring looms, manifold, intercooler and associated pipework and a hell of a lot more and you can't just transplant the 2.0T turbo onto it as the ECU won't run it.
    Regular Member Jezzy's Avatar
    S.E
    Plus water and oil lines to and from the turbo, and you'd probably need to reduce the compression ratio.
    Regular Member Kev_A's Avatar
    Gateshead, Tyne and wear
    Engine : Z20NET
    Tiy tried the z22SE forum?
    It's probably do-able but you'd need your turbo and associated hoses, intercooler, injectors, fuel pump, manifold and exhaust, some form of management, whether you could get the stock ECU mapped or simply run a piggyback or standalone ECU.
    Wouldn't be kind to your wallet that's for sure, with the price of 2.0T's (complete car not just the engine) now you might aswell just buy one of those!
    falkirk
    if your modding a 2.2se/2.2yh forget the turbo idea look into a supercharger few cars on www.z22se.co.uk there is a guy on ther voccy he knows the engine inside out and there is another guy who makes tuning parts for the 2.2se thinks his user name is atom x if i recall correctly there have been done with good results especially the silver vectra b
    Jan 2008
    South Wales
    I agree with matt0785. Retro-fitting a Turbo is pretty messy. Fitting a Supercharger is much simpler. You can buy Eaton superchargers, the type used on the Mini Cooper S if I remember correctly, which are pretty self contained. They have their own oil and internal clutch. You need to supply a direct drive from the crankshaft and lots of mapping and calibration.
    I looked at lots of options but opted for a 2.0T model Much simpler option.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Not a problem on the SE as its a straight bolt on swap, well near enough, but the YH's has swirl flaps in the manifold and unless you can find anyone that can map that out of the stock ECU then its going to be in constant limp. The inlet ports are totally different on the YH to the SE and NET as well so a custom manifold would need to be made, although as I mentioned earlier I believe the zorst ports are the same.
    As said though, Vocky and Atom X are the guys to speak to although Atom believes Forced induction is the work of the devil LOL.
  1. Replies: 19
    Last Post: 6th September 2014, 13:54
  2. Turbo Technics Hybrid turbo details.
    By nutron in forum Diesel Engine related
    Last Post: 28th February 2011, 22:57
  3. TD04L14T turbo for Z20NET (2.0 turbo)
    By Caveman_nige in forum Parts for sale
    Last Post: 10th October 2010, 13:23
  4. Turbo Help
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 12th February 2010, 11:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
