Thread: clutch is not springing back correct position
    Sep 2009
    newcastle
    Default clutch is not springing back correct position
    i was driving on the motorway when i went to drop a gear to slow down a bit the clutch was in the depressed position but not fully down when i pressed the pedal it was still working but very stiff to press i manage to get home and have a look and lifted the pedal back to the correct position and it now seems to be working ok has anyone had this trouble before also there is a noise coming from the release bearing which seems to be getting worse.
    cheers in advance
    Regular Member sebadee's Avatar
    macclesfield
    Had a similiar thing with mine where it occasionally stuck down but after a while it totally went turnt out the slave cylinder was shot and leaking fluid
    Not saying that's ways wrong with yours though
    Engine : 1.9 CDTi
    As above.
    Sounds like the slave cylinder is leaking and now contaminating the bearing/clutch
    Sep 2009
    newcastle
    whats the damage on getting that done with good parts approx
    Engine : 1.9 CDTi
    About £500-£600
  1. These the correct ones?
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 28th December 2012, 03:06
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. how to refit dlc back in position?
    By NIGHTCD in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2010, 16:21
  4. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
