Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Ticking noise v6 cdti engine
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Default Ticking noise v6 cdti engine
    Hi guys wondering if anyone could help with ideas what problem might be
    My v6 has a ticking noise a lot more noticeable when hot.
    I think it could be injector related as my rev gauge fluctuates by about 15-20 revs.
    I've listened to each injector with a large screwdriver and they all sound near enough the same. So I no I need to perform a leak off to test to gauge their condition accurately. But was wondering for other ideas before I have to pay a gauge for this test as I don't have a leak of kit.
    Bit of back ground info, I bought the car on 102k needing a headgasket I changed headgaskets an belts etc. It's now just shy of 106k runs absolutely great bar this annoying ticking sound.
    One of return coolant hoses has swelled slightly as seen in the video. I have lost a tiny amount of coolant in the milage coverd from this pipe a new one has been ordered.
    I've included a video of what car sounds like once warmed up.
    <a href="http://s287.photobucket.com/albums/ll142/critchleyal/?action=view&current=5022299c.mp4" target="_blank"><img src="http://i287.photobucket.com/albums/ll142/critchleyal/5022299c.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
    And another
    <a href="http://s287.photobucket.com/albums/ll142/critchleyal/?action=view&current=249318a4.mp4" target="_blank"><img src="http://i287.photobucket.com/albums/ll142/critchleyal/249318a4.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
    And here's a video of engine before the headgasket was changed
    <a href="http://s287.photobucket.com/albums/ll142/critchleyal/?action=view&current=IMG_0628.mp4" target="_blank"><img src="http://i287.photobucket.com/albums/ll142/critchleyal/IMG_0628.mp4" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Maybe unrelated, but I had an MG ZS 2.5 V6,and about 2 months after the ticking noise started, my timing belt chewed through the pulley housing-not repairable. My revs fluctuated as well so I dunno if u want to take a look at that.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I'm having the same problem. It's not injector related, but it's the ****** pulleys.
    Mine
    http://www.youtube.com/watch?v=mP8f6idrDBw
    http://www.youtube.com/watch?v=ARJfQNEWL0A - engine is much louder on the pulley side
    and when cold
    http://www.youtube.com/watch?v=M1pKpi3G9U4
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Might be my hearing but seems worse opposite side to pulleys :s
    What's best way to check them? Does timing belt need to come back off?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Quote Originally Posted by Celes View Post
    Mine
    and when cold
    Just watched those videos pretty identical sound. I never thought to get down an check underneath like the second video I will try that later.
    Do you a way of solving the problem?
    It had a new belt idlers an tensioner fitted when head gasket changed
    Noticed the mileage is 102K miles
    When was the cambelt changed?
    Was just the cambelt replaced or was the kit fitted?
    Your eyesight must be good if you can see a variance of 15 to 20 revs on the tachometer!
    Can you descirbe the variance, does it wobble, click, or erratic?
    If you raise the revs in neutral does the variance continue?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Full kit was replaced when head changed ie new idlers belt and tensioner aswel as aux belt
    I had it plugged into diagnostics that's how a could see the variation of revs
    If you rev then revs as normal
    It fluctuates just very slightly ie up and down on the same point if that makes sense. think you can just about make it out in the first video
    You are always going to get a variance in the revs, due to the toleranaces
    You would really need to know what these are before determining if there is a fault that needs investigating
    The analogue tachometer is +/- 100 units , so +/- 50 should be well within normal operation
    My tachograph needle clicks/jumps in neutral, but you need to be close up and concentrating to see it occur
    The diesel specialist I use could not find anything wrong, he suspects the sending unit has simply become contaminated during the cambelt change
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    Yeah I agree I'm not to fussed about the needle moving as it's such a small variation it didn't concern me that much it's the ticking that I want sorted. And mentioned the variation in revs incase that had any link to it.
    So does yours move the same? Ie mine idles at 900 revs and the needle will fluctuate up an down on the same the point.
    Also does everyone agree there is a ticking noise in my engine an it's more than likely the pulleys?
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
  1. Ticking noise from rear of engine
    By steveyd83 in forum Engine & Drivetrain
    Last Post: 20th September 2012, 21:57
  2. Ticking noise from engine??
    By Gracey in forum Engine & Drivetrain
    Last Post: 31st January 2012, 00:23
  3. ticking noise from engine
    By johnny ni in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 23:16
  4. Vectra C 1.8 SRI engine ticking noise
    By peternotails in forum Engine & Drivetrain
    Last Post: 1st October 2009, 20:25
  5. Ticking noise from engine... more so near the injectors
    By JonR in forum Engine & Drivetrain
    Last Post: 28th January 2008, 20:54
