Results 1 to 10 of 15
Thread: Rear Light Loom Gloom
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Default Rear Light Loom Gloom
    Does anyone know where the looms plug in for the rear lights? I think i've inadvertantly caused an earth when playing and now I get an intermittent bulb warning and super fast indicators on the passenger side. Changing the pins back to what they were doesn't help either so I think I've knacked the loom. Part numbers and prices would be a bonus as well please guys.
    Mar 2011
    Mar 2011
    Wednesday Anyone Help?
    Regular Member C-Owner's Avatar
    May 2011
    South London
    Are all the indicator bulbs are working ok with the hazards on.
    Mar 2011
    My indicators are fine until the bulb warning lamp comes on (all bulbs are defo good). Then with the warning up I get fast indicators after indicating left and it will continue to do so until I restart the car. While I have the "fast indicators", the hazards do not work on that side. Its a weird one.
    carlisle
    I had a problem with intermitent bulb warnings and then the scary experience of every bulb warning light possible coming on and the end part of the loom went on fire . It was a fortune to replace £300+ if I remember and the labour was going to be mental. The garage cut the wire where it was damaged and replaced the connector with one from a breakers, ended up being about 45 quid and hasnt faltered yet maybe another option for you. Would flashing indicators not be an indicator bulb out?
    Mar 2011
    An earth somwhere would make it do that as well, I've got a fair bit of time off now so i'll be able to look at it more, but i'm pretty stuck at the mo.
    May 2011
    South London
    Just to clarify
    What was it you were doing at the time to cause the fault ?
    Dublin
    I'm experiencing the same problem! I was living with a blub replacement light on the dash for a few weeks and it looked like the culprit was a missing rear red light. I replaced a bulb in the the rear cluster yesterday and now the rear indicator/hazard light on that side no longer works, and I also get super fast indicator speed for that side in the dash. Would really appreciate some advise on this one!!
    Mar 2011
    Quote Originally Posted by C-Owner View Post
    Just to clarify
    Nothing at all, the bulb warning is random, when it comes on, only my left indicator goes fast, and only the left indicator doesn't flash when the hazards are on.
  1. rear interior light no loom
    By Rob12 in forum Electrical & ICE (including SatNav)
    Last Post: 17th March 2012, 18:44
  2. rear interior light- no loom !!
    By n8sby in forum Styling
    Last Post: 17th May 2010, 16:02
  3. Rear Interior Light - Loom Info
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 9th April 2007, 16:48
vauxhall vectra c estate rear light wiring loom
