Results 1 to 10 of 16
Thread: Power Steering failed then started working....
    Regular Member adamtaylor's Avatar
    Witney (OXfordshire)
    Default Power Steering failed then started working....
    Hi All
    My wife just came home and said the power steering had failed and the stering wheel with explanation mark warning light was on on dash. When she got home we turned the engine off and on again and it is all working fine and no warning light on. Just wondered if this is something thats hapened to others and if anyone knows why it would happen?! (Cars an 07 1.8vvti)
    Cheers in advance
    Ads
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I'd check the fluid level first if I were you
    Regular Member smiley-sri's Avatar
    Jul 2009
    Tamworth
    Check your battery connections
    VOTING UKIP IN AVELEY
    20 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    could be steering rack...or maybe alternator ...
    but as said firstly ck your p/s fluid.
    Mar 2011
    S
    This same thing happened to me on thursday. Just went stiff whilst doing a 3 point turn so switched off and on again and it was fine. Fluid level ok. No lights on dash. 1.8vvt sri 2006.
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    If you have a Multimeter check the voltage at the battery with the engine running 13.5-14.4 is ok, below that alternator may be on its way out.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    I mentioned this in another post, but I'll put it here too for these members... I had intermittant issues with my PS cutting out and going stiff for a few seconds/minutes at a time. As I didn't have time to drain and refill the entire steering system, I siphoned the fluid out the reservoir, and refilled that with new fluid. This worked a treat. The following week, I drained teh entire system when I had the time. Been fine since. That was 10k miles ago, and still feels like new.
    HTH
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    How much fluid did you need to do the whole system?
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Think I used about 3 litres. Not sure if it was all drained out, as my container was getting full, and I was lying uncomfortably under the car, so I re-attacthed the pipe, and filled with new stuff.
    HTH
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 iVtec
    Mileage : 65500
    Yea thanks, I doubt its possible to get it all anyway, how easy would it have been to just add drain plug
  1. Power steering stopped working
    By SongBird in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2012, 17:08
  2. Power steering not working
    By gazspeight in forum Vectra C / Signum Troubleshooting
    Last Post: 30th November 2011, 19:08
  3. Replies: 12
    Last Post: 16th April 2011, 21:46
  4. Failed Power Steering
    By bigboynigs in forum Suspension, Wheels & Brakes
    Last Post: 15th December 2007, 17:44
  5. Power steering failed
    By Nealsey in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2007, 18:57
