Thread: Fitting a starter motor - can someone please explain how2
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Exclamation Fitting a starter motor - can someone please explain how2
    Hiya,
    Not had a chance yet but could someone please explain to me how to change the starter motor on my vectra 2.0 dti estate 2004.
    I will need to do this with the battery hooked up because I don't have the code for the radio and don't want to lose this....
    thanks guys - going to do this tomorrow
    James
    Engine : 1.9 CDTi
    You wont be able to do it with the battery connected because you have a battery live (And its a thick one too) going to it that you need to remove.
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    plus its a big pain in the ass to remove i did mine and its very tight behind turbo as you have to get right behind for fixing mount screws
    Irmscher Insignia CDTI 130
    Mar 2011
    M4 Junc 12
    bump
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    Unless you are prepared with a dictionary of swear words and prepared to loose some skin, I would stick it in a garage. And i didnt have a turbo in the road! Mine cost me 60 quid in labour.
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    I did mine it it took me a while and plenty of skint knuckles and swear words lol
    You have to disconnect battery and iirc there's 4 torx nuts holding on heat shield,then theres another 2 torx nuts holding the starter motor bracket right behind turbo half way down back of engine ( these are the ones that gave me most grief)
    Then there's a bolt going through gearbox into starter and one below,then you have to undo bolts for power cable and earth lead on starter.
    There's not a lot of room because of down pipe and drive shafts i think in haynes manual it tells you to remove down pipe but i just managed but its very tight
    Mar 2011
    M4 Junc 12
    thanks guys - appreciate it I'll give this ago as soon as the rain eases up
    will let you know how I get on....
    Nov 2010
    BRECHIN
    Quote Originally Posted by wingz123 View Post
    Best o luck mate
  1. Starter motor
    By lencuff in forum Y & Z30DT Specific
    Last Post: 9th January 2013, 21:09
  2. Starter Motor?
    By Danny.surname in forum Engine & Drivetrain
    Last Post: 11th July 2012, 21:40
  3. Starter Motor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 14th May 2012, 18:57
  4. 2.2 dti Starter Motor
    By bobast in forum Engine & Drivetrain
    Last Post: 11th March 2011, 12:04
  5. new starter motor
    By magpie27 in forum Engine & Drivetrain
    Last Post: 19th May 2009, 13:46
vectra 2.0 dti starter motor removal
vauxhall vectra starter motor removal site:www.vectra-c.com
