Results 1 to 3 of 3
Thread: Rubbing Drone noise front wheel
    Tarbert
    Default Rubbing Drone noise front wheel
    Hi got a 55 cdti 150. Noise coming from the drivers front wheel sounds like a cross between the tyre rubbing on something (checked it and its not!) and a droning noise. Noise only present at speeds above 20mph, around 50 and 60 noise not so bad but thats maybe wind drowning it out? I am guessing it will be the wheel bearing, tried jacking it up but there is no noticeable movement. Any other ideas if it may be something else? cheers
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Sounds like wheel bearing
    Try swapping the front tyres with each other and see if the noise moves to the other side. If that's the case, it'll be tyre noise.
    hth
    Regular Member Pete B's Avatar
    Malvern
    Just what mine sounded like when the wheel bearing was running dry. Unfortunately, the lack of obvious movement with this type of bearing is by no means conclusive, gauges have to be used to determine the very small amounts of movement likely to be present.
    As above, check tyre noise but also check just by rotating the wheel on each side while jacked up. With mine, it was easy to determine by that method alone which bearing was noisy.
    Hopefully, the "How To" Mods will put up the "How To" I submitted last week on the procedure for changing them.
  1. Rubbing noise from rear wheel
    By Mike RB in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2012, 19:03
  2. Rubbing noise nsr
    By pipamish in forum Suspension, Wheels & Brakes
    Last Post: 27th December 2011, 01:05
  3. Drone/hum - crap tyres or wheel bearing?
    By bigdave1701 in forum Suspension, Wheels & Brakes
    Last Post: 30th August 2011, 20:04
  4. noise from the front, tire rubbing suspension?
    By Adamdavi3s in forum Suspension, Wheels & Brakes
    Last Post: 21st May 2008, 11:15
  5. "Grating / Rubbing" noise from front end
    By stripey in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2007, 17:05
vauxhall insignia droning noise
vectra c droning noise
vectra c drone
vectra c front droning noise
drone above 20mph wheel bearings
vectra c cdti 150 wheel bearing
vectra c wheel bearing noise
astra xp droning noise
vectra noisy wheels
vectra c droning noise from front
drone from front wheel
07 vectra 1.8 petrol front wheel bearing noise
VECTRA C VXR RUBBING NOISE FROM FRONT WHEEL
vectra c 1.8 humming noise
opel signum noise from front wheel
