Thread: Rear Brake Discs & Pads
    Regular Member Casper85's Avatar
    Apr 2011
    Salisbury
    Vehicle : Vauxhall
    Trim : Vectra SRi
    Engine : 2.2direct Z22YH
    Mileage : 54600
    Default Rear Brake Discs & Pads
    Hi all,
    as mentioned before, my car passed it's MOT with an advisory of N/S/R brake pad wearing thin.
    I know to replace both the N/S and the O/S pads at the same time, but should I also replace the discs as well while I'm at it????
    Nothing was mentioned about replacing the discs when I collected the car from the MOT.
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    Depends on disc wear, I've just changed all the discs on mine at 50 k,
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    If you've got the coin to change them. I'd do it at the same time. Considering you're pulling the whole brake assembly off, it makes sense. If not, really doesn't matter. You'll just have to do it all further down the line.
    11 Post(s)
    Buying a brake kit (comprising discs and pads) is cheaper than buying the discs and pads separately.
    As the pads are almost as hard as the discs these days, chances are the discs are worn and need changing.
    Mar 2013
    WARRINGTON
    Vehicle : VECTRA C
    Trim : EXCLUSIVE
    Engine : 1.8 VVT
    Mileage : 45570
    Are the disc and pad set up different between a 55 reg and an 07 Vectra C 1.8 vvt?
    I cant find the mounting bolts for the caliper....
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Nope, there were only ever two sizes of rear brakes fitted to the Vec-C/Signum. 278 fitted to everything bar the 2.0t and v6s which had 292 rear discs
  1. rear brake discs and pads
    By rfc52 in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 15:09
  2. rear brake pads and discs
    By geebee007 in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2010, 01:40
  3. FS: Rear brake pads (For 278mm non vented discs)
    By John LE in forum Parts for sale
    Last Post: 7th January 2010, 18:07
  4. FS: Rear Brake Discs & Pads
    By gary k in forum Parts for sale
    Last Post: 16th March 2009, 11:23
