Results 1 to 10 of 26
Thread: Power steering fault
    Regular Member gazspeight's Avatar
    May 2011
    Durham
    Exclamation Power steering fault
    Hi Guys, i'm new to this website & i'm impressed with the knowledge & support you give out!
    Ok, i have a Vectra SRi (Facelift)55plate 1.8 petrol, from day 1 i've had intermittent problems with the power steering going stiff. I've had into a garage & put on the diagnostics, the guy said i need either a new ECU or Power steering module & quoted me around £200 for the module supplied & fitted, if this doesn't rectify it then i'm looking at £600 for a new ECU!!!
    Any remedies or tips i could DIY, i understand that if i fit a new module i still have to go & get it married up!
    May 2011
    lancs
    Hi Mate new myself to diesels apart from work vans that were covered but done an awful lot of reading before i bought anothe car after owning a mondy 52 plate 1.8 zetec from new, Does the battery light come on when the steering goes stiff, if so have you had the alternator & battery checked, Don't know if it's the same on petrols but i looked at various saab tid's same engine as cdti's with power steering problems that pointed to this. Hope you get it sorted. Tommy
    May 2011
    Durham
    Cheers Tommy, No i have no lights come on when it fails. Just very stiff steering for a minute or two!
    May 2011
    lancs
    i know the corsa c has a electronic power steering common fault has my cousin has one lol he is only 5' 4" and twenty odd,
    the below is taken from another source regarding intermittent steering problem for a vectra 2002-2008 which is in your range
    first port of call will be a battery check and then a charging system check, the system that you have is known as EHPS Electro Hydralic Power Steering, if either is not up to scratch then this will/can cause problems
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Might sound daft, but have you checked the fluid level?
    I had exactly the same symptoms on mine (occasional stiffness), turned out I needed half a litre of fluid. That was 10k miles ago. Still fine now, and not dropped at all...
    hth
    May 2011
    Durham
    Cheers Tony-1977 it was the 1st thing i checked hence why i opted for a diagnostic. However i might change the fluid just to be on the safe side incase it's dirty!
    I'll get my battery checked as an air of caution, cheers!
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by gazspeight View Post
    If your car's a 2005 model, and the fluid's never been changed, I'd change it now. Dirty fluid caused my power steering to be juddery and it would just go off for a few seconds when it wanted to. I siphoned the fluid out the reservoir and refill it with clean fluid. That was enough to make it like new. A few days later, I drained the entire system and changed it all. Made the world of difference.
    As for the battery, stick a multi-meter across the terminals with the engine running. The reading should be 14 - 14.5 volts. If it's any lower, your alternator may be suspect, as the power steering uses a lot of power, it's usually first thing that shows a weakness.
    hth
    May 2011
    Durham
    I'm off Wednesday so i'll drain my system down & give it a whirl!!!! Cheers
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    If My Screen Goes Dim When I Turn Steering Wheel/Lights On/Heating Etc...Does This Mean A Dodgey Battery ?
    Aug 2010
    Dundee-Motherwell
  1. Power steering fault
    By Mattle40 in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2013, 13:50
  2. Power steering fault
    By andyfeeny in forum Engine & Drivetrain
    Last Post: 28th July 2010, 22:02
  3. Power steering fault ?
    By Saxman in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2010, 20:20
  4. Power steering fault??
    By treasure22 in forum Vectra C / Signum Car Chat
    Last Post: 18th March 2010, 15:50
Vectra c steering fault
