Thread: egr blanking with 10mm hole
    May 2008
    Wiltshire
    Default egr blanking with 10mm hole
    have had a restricting gasket with a 10mm hole preceding the egr for approx 18 months now. thought i would check it the other day, egr was not too bad but the entrance to the throttle body was quite sooted up. I place the blanking gasket in place straight after having a new egr and inlet manifold.
    didnt bother cleaning out the throttle body, didnt have the right torx bits!
    whats the smallest hole people have tried without getting eml? how difficult is it to get rid of the egr all together? would that have to be via a remap? if so what cost are we talking, is it worth it?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    There is no point fitting a blanking gasket with a hole, it will still gunk the manifold up the same. Its either leave alone, or fully blank it for me.
    Blanking gakset is about £4 off ebay, and it will be fine (but will have emissions light on) - about £100 for it to be mapped out of the ECU.
    Regular Member Big Red's Avatar
    May 2011
    Dudley (Cramlington)
    hi guys
    just new to this site and stumbled upon this conversation, i had a nissan navara which i just got rid of for my vectra 1.9cdti 120 and i had blocked the EGR valve off all together with a 1mm stainless steel plate i got from work (no hole) and i had no problems. i got better performance after some deisel addative to clean the engine out and it increased MPG. i am going to make a blanking plate for the vectra at work this week as it is definatly worth it in the long run.
    May 2011
    I meant to say aswell, once i did this the light came on on the dash, took it to my mates garage pluged it in to the computer and deleted the error code.........sorted!
    i know this was a navara but you can do it on the vectra too
    cheers
  1. 10mm torx ratchet spanner.
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2012, 15:11
  2. what size hole in egr blanking plate ?
    By deano1 in forum Engine & Drivetrain
    Last Post: 17th December 2011, 14:56
  3. 10mm wheel spacers fitted
    By R2XPT in forum Styling
    Last Post: 27th September 2011, 21:25
  4. Egr semi blanking plate.what size hole?.
    By felixx in forum Engine & Drivetrain
    Last Post: 1st October 2010, 00:26
egr 10mm emissions light
