Results 1 to 10 of 29
Thread: Blower works on 2, 3 & 4 but not on 1 ??
    May 2007
    Question Blower works on 2, 3 & 4 but not on 1 ??
    My heater blower seems to work OK on settings 2, 3 & 4 but not on setting 1.
    The common problem seems to be that the blower only works on 4 but not on 1, 2 or 3. - The common cause of this is a damaged resistor often due to water ingress via the scuttle tray.
    If settings 2 and 3 work, does this indicate a problem possibly with the heater control fascia/unit rather than the resistor ?
    May 2007
    West Yorkshire
    no, it's the resistor.
    West Sussex
    Quote Originally Posted by sshooie View Post
    Are you sure? I thought if the resistor was nacked the fan only works on 4.
    Are you sure it is not working on 1, as I find it of very low effort and as such have to use 2
    Try this
    Put the Air Con to OFF
    Turn the Setting to 0
    Put the Air Con to ON
    The system is now putting the air through at setting 1 (even though you have selected to 0), you can confirm this by moving it to 1 and there will be no difference, and then 2 and a slight increase
    May 2007
    Tried your test m8internet. I even closed off 3 of the 4 dash 'air outlets' (to concentrate the flow) and used a piece of tissue paper in front of the outlet. I'm as sure as I can be that there is NIL flow on on position 0 and on position 1, but good increasing flow on 2, 3 & 4.
    Any ideas ?
    For the test I posted you do NOT need to move the dial, leave it on position 0
    Start with the air con OFF
    After a few minutes, turn the air con to ON
    You should then feel air being blown through
    I recommend you position the air flow to face level
    Finally, does the car have a rear cabin vent?
    If so, close this
    May 2007
    Air flow to face level. Rear cabin vent closed. Followed all other m8internet guidance : NIL flow on setting 0 even after aircon switched on.
    Any conclusion ?
    Regular Member keith150882's Avatar
    Oct 2009
    boston
    Vehicle : Cdti 150
    Trim : Sri
    Watching this thread as my fan is the same !
    May 2007
    Default Blower works on 2, 3 & 4 but not on 1 ??
    Any further ideas/comments ?
    Regular Member Whisky's Avatar
    Mar 2011
    Kirkcaldy/Barrow-in-Furness
    Sounds like your heater controls are duff to me.
  1. Blower only works on 4
    By Sri-chris in forum Electrical & ICE (including SatNav)
    Last Post: 12th March 2012, 18:58
  2. Blower only works on 4
    Last Post: 11th December 2011, 18:46
  3. blower only works on 4
    By chris1804 in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 21:26
  4. Fan (blower) only works on 4 :(
    By sigtim in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2011, 20:01
  5. heater blower only works on 4 speed
    By hippo in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 9th February 2010, 14:38
