Results 1 to 2 of 2
Thread: cdti 120 starting cold
    Regular Member steve19cdti's Avatar
    Nov 2010
    s.wales.bridgend
    Default cdti 120 starting cold
    got problem with starting my vectra 1.9cdti 120 in morning and if i leave it for 5-6 hours
    first off changed glow plugs checked power going to them and relay been checked.
    if i wait for glow light to go out then start it straigt away it will take long time to start but resantly ive noticed a buzzing noise in boot must be fuel pump if wait for it to stop buzzing then turn over it will fire up first time
    any one got eny idea could it be the leak off pipes???
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    weird! that but i had a problem with a set of glow plugs i brought, when tested the original set glowed red within 9 secs but the replacement ones took 15, ( times quoted are for reference purposes only) so i replaced them with the same as the originals & problem solved.
  1. 56 plate cdti 120 cold and poor starting
    By bigbadcat in forum Engine & Drivetrain
    Last Post: 5th June 2012, 17:28
  2. Poor starting 1.9 CDTI 120 Hot & Cold
    By lehapau in forum Engine & Drivetrain
    Last Post: 4th October 2011, 20:06
  3. poor cold starting CDTi 120
    By bembo449 in forum Engine & Drivetrain
    Last Post: 21st May 2011, 16:53
  4. Starting in the cold
    By Rebellion8878 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2010, 22:15
