Results 1 to 10 of 19
Thread: Squeaky Brakes After New Discs & Pads??
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Squeaky Brakes After New Discs & Pads??
    Recently had a mate change my front brake discs and pads all round.
    Now they squeak and squeal more than they did when it was metal on metal.
    My guess is this, when he was changing the pads, he had to screw the caliper piston in to fit the new pads in, he didn't alter them all to be screwed in/out all the same.
    So when I brake, on one wheel, the piston could be pressing the pads on the disc more than another wheel, which is like the pad just resting on the disc as it's going round and not getting a tight squeeze, thus creating a squeak.
    The harder I brake the less it sqeaks, when just light braking coming up to lights or something, the screech makes me cringe.
    Does what I'm saying make any sense to what the problem could be, as I'm just a novice when it comes to cars.
    Thanks guys!
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    do the brakes pull to one side or the other thats what happens when the piston works harder on one side than the other
    my guess is they just need bedding in
    give it a week or so see what happens
    Mar 2011
    Wirral
    I will check as may be popping chinese in a bit.
    It's been about 3 months and about 1500 miles later and still sqeaks
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Cheap discs and pads by any chance? Cheap pads will squeal and the only answer is decent pads or live with the squeal
    Another thing to check is that the heat shield for the bottom ball joint isn't touching the disc
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    Another possible answer is were the pads and rotors worn in correctly? Now it won't change the fact that you're car is pulling to one side, but squeaking new brakes could be due to this.
    To bed in brakes. (Sorry I can't convert KM/H to MPH
    Take off to a speed of around 50km/h. Gently apply the brakes to slow the car to around 20km/h. Do this around 3-5 times. Next, do the same with slightly harder braking each time. This will bed in the brakes, and ensure that should you need to slam on the brakes after installing them, you won't completely glaze them and cause squeaking.
    Full Member Big Sig's Avatar
    Did he apply plenty of copper grease to the rear of the pads?
    exeter
    Thumbs up
    i agree you need to put cooper grease behide the pad that will stop the sqeak
    Mar 2011
    Wirral
    I'm not too sure, he was using a grey paste on loads of fixings and glue on threads but not sure on the back of the pads.
    Why does it cause a squeak if not put on back of pads?
    Also what is glazing? When he finished and I drove off I went back straight away as I wasn't happy as the car wouldn't break unless the pedal was to the floor, so he jumped in and was doing loads of emergency stops to test them, maybe this is the problem? Anyway to fix this?
    Thanks!
    If there isn't any grease on the back of the pads that will make them squeal like mad.
    exeter
    He should of pump the brake up and down then the hanbrake just to settle the piston down . But you really need copper grease to sort out the sqeak
  1. Purchasing Brembo Brakes Pads & DISCS SIZES?
    By Elahi_786 in forum Handling & Braking
    Last Post: 8th March 2011, 10:57
  2. squeaky brakes
    Last Post: 22nd June 2010, 13:19
  3. sponge brakes after new discs and pads
    By jstal40024 in forum Suspension, Wheels & Brakes
    Last Post: 1st November 2009, 17:19
  4. Squeaky Brakes
    By BENNYBED in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2008, 14:44
vectra new discs and pads squealing
vectra c squeaky rear new brakes
