Results 1 to 10 of 17
Thread: Rear Brake Disc (can't remove???)
    Jul 2010
    lancs
    Angry Rear Brake Disc (can't remove???)
    Hi,
    Just trying to remove my rear brake disc, as i am replacing the wheel hub.
    But i can't seem to get it off. I have taken off the pads,caliper, taken the 2 torx screws from the back, so all i have left is the disc. I have removed the retaining screw from the hub. But the disc won't pull off. Is there something else i need to undo. Or should it just pull of???
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    hit it with a really big hammer, its probably corroded on
    Administrator plasma's Avatar
    On the Forum
    360 Post(s)
    Engine : 150
    Mileage : 74000
    removed the torx/allen screw from the FRONT of the disc?
    edit: reread- seems you have, in that case REALLY BIG HAMMER time.. just rotate the disc as your doing it
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by triple595 View Post
    And twist/crack the disc in the process
    Get some wd40 and spray it through the bolt holes where the hub sits against the disc. Then when turning the disc tap a hammer around the centre of the disc bell.
    The hub should be covered in copper grease before putting the disc on as the disc can rust onto the hub.
    Very last resort will be to break the disc off (as i've had to do in the past)
    Another option is to remove the hub with the disc attached and then you can spray wd from the back and let it soak
    Regular Member Pete B's Avatar
    Malvern
    When I did my front hub about a month ago, the disc was corroded on. I held a piece of wood against the back and hit the wood with medium force and rotated the disc round so that I was doing it evenly at different points. I also put a couple of wheel bolts back in to stop it flying off suddenly. It fairly readily came loose. In my case, since I was replacing both bearing and disc though, it wouldn't have mattered if it had broken.
    As others have said, use plenty of copper grease on the hub/disc mount to stop the same happening again.
    lincolnshire
    have you slackened the hand brake shoes off ?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Quote Originally Posted by bembo449 View Post
    The Vec C/Signum uses the caliper for the handbrake
    lincolnshire
    just thinking about that , its the vec B that has inboard shoes , he will need to remove the carrier though , well at least one bolt and slacken the other ! then a good tap should bring them off
    Regular Member Jezzy's Avatar
    S.E
    Wear goggles when hammering the disk - bits of it can come flying off.
    S.E
    He's already done that.
  1. Rear Brake Disc Advice
    By dudley6623 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 10:03
vectra b cant remove rear disc
show me how to change rear pads and discs on a vectra b
removing disc from vectra 51
vectra c disk screw wont undo
