Results 1 to 10 of 11
Thread: F.F.S.Rear Gearbox Mounting gone now
    Regular Member MURDO's Avatar
    Co.Clare, Ireland
    Vehicle : Opel Vectra GTS Sport Z18XE
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Default F.F.S.Rear Gearbox Mounting gone now
    1 thing after another at the moment.
    anyone knowng if changing the rear gearbox mounting on a 1.8 SRI is easy enough, or what would be involved.
    Got a quote from a mechanic, for around 130 euro including the bush/mounting.
    Not sure if worth paying out that much if i could do myself.
    cheers in advance.
    Worksop
    wot does ur car do ie noise etc to no this as gone bud
    scotland
    just jack up / support engine , g/box and unbolt mount then replace .
    easier if you have access to a ramp obviously
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    getting a bit of a nock when going up and down the gears. its not permanent, but if the torq is a bit high when changing up you'd notice it more.
    Rear bush is what mechy told me, so don't wanna pay him if thats not what it is.
    Would like to have a squizz over the weekend to see if i can check it myslef.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Quote Originally Posted by gsxrster View Post
    Sounds straight forward enough. Where's the places i would support or jack it up, or would suggest what tools i need to do it myself.
    scotland
    get it up on axle stands if you cant get a ramp , then support the g/box at the base of the diff , use a trolley jack an block of wood , might be better to remove battery for access , remember to have radio code though !!
    Worksop
    Quote Originally Posted by MURDO View Post
    mines same were u get em from?
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Well. mechanic i went too said he'd get it for me, but not sure if i'll go back to him if i can do it myself. Would say any good autoparts place would have them, or main dealer if there not a silly price.
    Regular Member Keif's Avatar
    In the Garage
    I've just done this (and my front mount) on my 2.0T.
    The mount costs about £50 trade. So will be a little more. (Vec-c membership would have saved you some Euros)
    It's all of three bolts for your 1.8. You'll need a 16mm socket and 11mm ring spanner to undo the two bolts through your subframe, and a T30 torx socket (or 14mm socket) for the engine bolt.
    As said, get the car as high as possible of axle stands and support the engine/box on a bit of wood on a trolley jack, then venture under the car.
    Co.Clare, Ireland
    Trim : Matt Sivler
    Engine : Z18XE
    Mileage : 170,000
    Quote Originally Posted by Keif View Post
    Thanks man.
    Probably gonna give this a go tomorrow. Hopefully all ok.
  1. brake pipes - engine subframe rear mounting
    By DaveG in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 09:18
  2. Engine & Gearbox Mounting
    By redjohno in forum Engine & Drivetrain
    Last Post: 7th January 2011, 00:15
  3. PDA Mounting
    By Damian in forum Electrical & ICE (including SatNav)
    Last Post: 18th May 2007, 17:12
