Thread: noise after replacing crankshaft pulley
    birmingham
    Default noise after replacing crankshaft pulley
    Hi,can anyone help please,about a week ago the crankshaft on my 53reg 2.0 dti broke off,i drove home about a mile with the fan belt off,then i drove to the garage with no fan belt,about another mile,i bought a crankshaft pulley,not original part and had it replaced,the problem now is that there is a sqeeking noise comming from the fan belt and sounds abit rough on idle,i didnt change the fanbelt,could any of the other pulleys be damaged because i drove couple of miles without fan belt,also ive noticed the fan belt looks a bit loose when car is running as it slightly wobbles up&down,is that normal? but is pretty tight when engine off,just to add the crankshaft pulley broke while car was at idle.Any help would really be appreciated. thanks
    West Sussex
    Quote Originally Posted by postman111 View Post
    Same problem as me, see my post of a couple of mins ago, aftermarket pulley seems to be the culprit
    birmingham
    Quote Originally Posted by Croxley View Post
    I bought mine off ebay,it was more solid than the original one i took off,this one off ebay didnt have the soft rubber on ther outside,have i f*ck*d up on this replacement part?
    West Sussex
    My original one broke away when it was idling, when I started in fact. I bought one on line for £80, got a local guy to replace it, ever since it has made noises, vibrated and squealed (a lot) prior to that it was fine.
    I've just bought a VX part which is totally different to the cheap one. In answer to your slightly naughty comment I would say yes.
    birmingham
    How much is the VX part? have you fitted it yet?
    Regular Member toon sri's Avatar
    newcastle
    170 m8
    West Sussex
    Quote Originally Posted by toon sri View Post
    170 m8
    I paid £175+
    West Sussex
    I'm in the process but having trouble getting the nut to shift!
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Was the one off ebay a lot heavier than the original you took off.?
    If so thats the reason for the noise on idle. Need to change it to an original vx pulley.
    Regular Member tosh23's Avatar
    HULL
    Im wondering if you could do us all a favour..
    Could you weigh the original pulley ( if its all there) and also weigh the aftermarket part...
    I would love to know how much of a difference there is...
    Apparently the aftermarket one weighs alot more.
    http://www.vectra-c.com/forum/showthread.php?t=138608
    In this thread I have posted the weight of the aftermarket part ..Is yours the same weight ??..
    Also does your pulley look like mine??/?....Tosh
  1. Crankshaft Pulley. Worth replacing?
    By Marky in forum Engine & Drivetrain
    Last Post: 3rd August 2010, 22:09
  2. Crankshaft Pulley
    By 123ashleyp in forum Engine & Drivetrain
    Last Post: 5th March 2010, 12:37
  3. crankshaft pulley
    By djsoundman in forum Engine & Drivetrain
    Last Post: 20th November 2009, 12:05
  4. Crankshaft Pulley again!
    By ANDY H137 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2009, 14:34
  5. Yet Another Crankshaft Pulley!
    Last Post: 13th January 2008, 00:27
vectra dti bottom pulley broken
2.0 dth auxiliary belt running of centre
bottom pulley vectra c noisy
vectra c crankshaft pulley noise
vectra c crank pulley broke
