Thread: Help!! Power steering making strange noise
    in a house
    StatsVehicle Info
    Default Help!! Power steering making strange noise
    Just been out in the vec and when we started it up there was a noise coming from under the bonnet so i had a look but couldn't really identify where it was coming from. it then started to quieten down so on we went. Got back in it from the shops and as soon as i started it up the noise came back, not to loud just a low droning sound, as i turned the wheel it stopped. when i didn't turn the wheel it returned, so im guessing its the power steering pump.
    Tried to find the reservoir for the fluid but i cannot see it anywhere under the bonnet, just hoping it needs more fluid,
    any ideas anyone ???? thanks
    Are you VXR Enough
    13 Post(s)
    StatsVehicle Info
    13 Post(s)
    the tank is either in the drivers wheel arch or on the bulkhead bud sounds like it could be low on fluid
    in a house
    StatsVehicle Info
    I do hope so chris, cheers
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    StatsVehicle Info
    were you from phil i filled mine up a few weeks back and i didnt need much nealy have a full bottle left if you live close you can have it
    in a house
    StatsVehicle Info
    Cheers guys for the replys, any more out there?????
    and chris1804 thanks very much for the offer of the fluid, much appreciated.
    My mate has some as he works for a garage, but cheers anyway.
    May 2008
    Tyneside
    StatsVehicle Info
    Lots of posts about power steering fluid, search "central hydraulic fluid". They recommend you use vauxhall CHF (central hydraulic fluid) to top up which is green. Mixing fluids not recommended. HTH
    Oct 2009
    UK
    StatsVehicle Info
    If it's like mine, in the driver's wheel arch, can be difficult to top up. Remove the wheel and arch-liner. Reach in and remove the cap (green bottle), then there's a little filter in the neck of the bottle. Lift this out. It's hard to see the level, so put your finger in and feel for the fluid. To top it up, I placed a length of hose pipe down from the top, into the bottle, and poured teh fluid in that way.
    I only needed about half a litre, but the steering is now a lot smoother and silent now. That was 12k miles ago, I checked the level again and it's not dropped a bit. So no leaks.
    Hope this helps
    in a house
    StatsVehicle Info
    bump for help/advice please
    StatsVehicle Info
    Have you checked the fluid level?
  1. Power steering pump noise? but no steering problems
    By bennettboy in forum Engine & Drivetrain
    Last Post: 2nd November 2012, 21:33
  2. 2.2dti strange noise and complete power loss
    By chrislloydie in forum Engine & Drivetrain
    Last Post: 28th May 2011, 16:09
  3. strange noise when giving power
    By twaiter in forum Engine & Drivetrain
    Last Post: 25th October 2009, 00:39
  4. Power steering noise
    By wylieeeeeeeee in forum Suspension, Wheels & Brakes
    Last Post: 23rd July 2007, 20:40
  5. power steering noise ?
    By shillbag in forum Vectra C / Signum Car Chat
    Last Post: 6th October 2006, 16:33
what noise does a vectra c make when driving whensteering fluid is low
vectra power steering making strange noises
